LED Lights
Discussion in 'Lighting' started by Hotround, Aug 15, 2021.
  1. Aug 15, 2021 at 9:49 PM
    Hotround
    Hotround [OP] New Member
    2011 Tundra
    Have a 2011 Tundra... Great Truck! Just put LED bulbs in the Low Beam side, and I can see where I am going!. Now i need to complete the job. What are the correct LED bulbs numbers for the:
    High Beams
    Front Turn Signal
    Side Marker
    Tail/Brake
    Rear Turn Signal
    Back Up
    Rear Side Marker (if there is one)
    High Mount Brake
    Cargo
    Liscence Plate
    Any problems requiring load resisters?
    Thanks in advance!
  2. Aug 15, 2021 at 10:06 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Most the interior and smaller exterior lights (third tail, plate, etc) are t9s. The more major lights are typically 3157s, highbeams and such depend on your headlight housing. Easiest thing to do is take off the light and check the bulb/fixture, should be stamped on both. If you want a quick and easy cheap led set that takes care of almost all the small stuff, I had good luck with this: Amazon.com: AUTOGINE Super Bright 6000K White LED Interior Light Bulbs Kit Package for 2007-2019 2020 2021 Toyota Tundra + Install Tool: Automotive. As for the major bulbs, pick a brand you like and swap.
    IgotSR5onit likes this.
  3. Aug 15, 2021 at 10:21 PM
    IgotSR5onit
    IgotSR5onit New Member
    How do you like the LED interiors? Do they affect your driving at night when turning them on/off?
  4. Aug 15, 2021 at 10:47 PM
    Gravy
    Yucaipa, California
    Can't say that I've ever turned them on while driving... it's a much whiter light, as for maybe glaring out the windshield, dunno.
  5. Aug 15, 2021 at 11:16 PM
    hhenry_
    hhenry_ New Member
    Bay Area Ca
    08 tundra crewmax
  6. Aug 25, 2021 at 1:32 PM
    bjens73_07Tundra
    bjens73_07Tundra New Member
    Brandon
    '07 Silver Tundra TRD
    i started to do this, by the third LED i installed, i blew the fuse. is it just a matter of putting a higher amp fuse in there, like a 3 to a 10?? anyone?
