LED Lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by texastundra77, Dec 7, 2020.
  1. Dec 7, 2020 at 6:05 PM
    texastundra77
    texastundra77 [OP] New Member
    Anthony
    2016 Tundra SR5
    I have an idea of installing small white led lights under the truck to illuminate the ground when the doors are unlock. Similar to the lights in the bed of the truck. Is there a diagram that shows which wires I need to tap into?
    ant8262 likes this.
  2. Dec 7, 2020 at 6:34 PM
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    I don't have a wiring diagram, but, I did mine by just testing the wires under the driver's side kick panel with a multimeter. If you are interested I'll pull my truck apart in the morning tomorrow when it is light out and try to figure out where I hooked everything up.
    Mine is hooked into the Cargo Lamp circuit by the way.
    Tommy's Tundra and Saltyhero13 like this.
  3. Dec 7, 2020 at 6:47 PM
    texastundra77
    Anthony
    2016 Tundra SR5
    ok so when you hit the unlock function on your key fob thats when the lights come on? Ahhh, I think I understand now. The light switch that turns that light on or when the door opens is the switch I can tap into so to speak.
  4. Dec 7, 2020 at 7:03 PM
    APalmTree
    Brandon
    SW Washington
    Yup my lights come on when I hit the key fob or when a door is open and the switch is set to the door position. I'm not sure if you can tap straight in behind the switch because it is possible that the switch triggers a relay. Mine is hooked up under the trim panel under the door. I don't have a picture right now but I'll get one for you.
    Gunship Guy likes this.
  5. Dec 7, 2020 at 7:10 PM
    texastundra77
    Anthony
    2016 Tundra SR5
    man thanks a lot. I really appreciate it.
  6. Dec 7, 2020 at 7:57 PM
    biebs96
    PA
    I wired mine to the footwell lamp circuit.
    This allows them to fade on/off with unlock, lock, door open, etc.
    https://youtu.be/Q5VmAUuNGnE
  7. Dec 7, 2020 at 8:06 PM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    That's awesome
    biebs96[QUOTED] likes this.
  8. Dec 7, 2020 at 8:13 PM
    biebs96
    PA
    thanks! I have a strip under the rear bumper and in the grill as well. Lights up the entire area around the truck when entering or exiting. Probably my favorite mod.
  9. Dec 7, 2020 at 9:16 PM
    LS3
    LS3 New Member
    2021 TRD Off-road Premium
    great job with that grille!
  10. Dec 7, 2020 at 9:56 PM
    TrucksRCool
    TrucksRCool New Member
    Jordan
    UT
    2021 CM Limited Nightshade
    Check out this thread. I also wired mine up like this by tying it into the small footwell light that comes on when the door is opened (or when door is unlocked). Post #89.
    https://www.tundras.com/threads/blue-ribbon-4x4-build-thread.71556/page-3
    Ignore the ADD inducing light show on the side. Parked in front of one of those laser Christmas light projectors at my friend’s house. Looks pretty cool though.
    Tommy's Tundra, RobertD and biebs96 like this.
  11. Dec 7, 2020 at 10:07 PM
    soobahru
    soobahru New Member
    2015 tundra 5.7L double cab 6.5ft 2019 tundra 5.7L limited crewmax
    If you could post a picture of where you tapped into the wire that'd be really helpful.
    Kee up the great work and thanks in advance!
  12. Dec 7, 2020 at 10:08 PM
    soobahru
    soobahru New Member
    Liking that grill light. Mind sharing where you got the light strips?
  13. Dec 7, 2020 at 10:12 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I also tapped into the footwell lamp with my custom puddle lights and my floorboard lights.
    I used vled puddle lights, very bright.
    3gnu04bz_zpsgecrr1ak_2df32e71398228ccec612352af0fe3e8ae6d3a33.jpg jq1k2l34_zps6rwjs4ah_5f0850f62e7f731e49737522dfa0b880cc6b2300.jpg
    fottwell%203_zpsfd7vjt6j_c245748195e416beecf2df6a403efe00e225ddb0.jpg fottwell%204_zpslbuhodom_516763fae38bb39fb3c3c053ca8b2fe1cad3aec2.jpg
    Tapped into the dome light for the Amp step lights so they come only when the doors open and the steps come down.
    I used aluminum superbright led bars for the steps and panted them OEM MGM to match the body color.
    Waterproof Linear LED Light Bar Fixture w/ DC Barrel Connectors - 675 Lumens | Super Bright LEDs
    TrucksRCool and biebs96[QUOTED] like this.
  14. Dec 8, 2020 at 3:15 AM
    biebs96
    PA
  15. Dec 8, 2020 at 9:40 AM
    APalmTree
    Brandon
    SW Washington
    Alright y'all, as promised I've got pictures. I will tell you where I have my lights tapped at the moment, BUT!!!! I really like the way @biebs96 did his and I will be switching my wiring up to match that and I'll show you how I think he did it and he can confirm or deny if he wants to. So, as for how mine is hooked up right now, IMG_1963.jpg
    You can see the little red wire poking out of the factory harness right by the drivers seat.
    I found a post a while back that said the color was a brownish-purple. The little wire on the far left I the one that I finally figured out was the correct one. As you can see from all the electrical tape It was quite literally the last wire that I tried, you know how it goes :confused:. I have no idea how to tell you which one is correct but I'll continue with the rest of the wiring.
    I pulled this little rubber plug from the bottom of the truck and then in the hole inside the truck I could see the ground and I fished the wire through to the outside of the truck and replaced the rubber plug. I grounded my lights to a random bolt that I found that was pretty close and was easiest to get to. From there I think the wiring should be pretty self-explanatory but I'll help you out if you still have questions.
    Now for the way I think the others have wired theirs up, and the way I will be switching to in the future when I have some time.IMG_1968.jpg
    This here is the courtesy light, mine has been replaced with an LED.
    You can pull the light out by giving it a gentle twist and it will pull out towards the front of the truck, this is easier when the E-brake is depressed fully out of the way, and then you will be able to splice into the wires there which is way easier than what I did so I would highly recommend this way instead!!! My plan is to extend my wire that already goes outside the truck and tap into whichever wire is positive, I have not found that out yet.
  16. Dec 8, 2020 at 10:20 AM
    biebs96
    PA
    Awesome! It is a closed circuit. So in order for it to fade on and off both wires (pos and neg) need to be connected to each of those wires.
  17. Dec 8, 2020 at 10:22 AM
    APalmTree
    Brandon
    SW Washington
    Good to know. Thank you very much!
  18. Dec 20, 2020 at 9:21 AM
    mghtyducks93
    mghtyducks93 Bubble Head
    Southern California
    2015 White Double Cab
    Hoping to install my LED's just like this today! Where on the inside of the hood did you place the lights? And did you run it through the firewall?
  19. Dec 20, 2020 at 9:27 AM
    biebs96
    PA
    the grill lights are on the underside of the top piece of the grill assembly that bolts and clips to the front of the truck.
    through the firewall is easy. There is a nipple on the grommet that houses a large portion of wires. Just cut that off and it passes through.
    ElNopal likes this.
  20. Dec 20, 2020 at 9:30 AM
    mghtyducks93
    Southern California
    Makes sense. So you removed the grill to add? Appreciate the help!
    biebs96 likes this.
  21. Dec 20, 2020 at 9:32 AM
    biebs96
    PA
    correct
    mghtyducks93[QUOTED] likes this.
  22. Dec 20, 2020 at 9:36 AM
    mghtyducks93
    Southern California
    Thank you! Good looking truck by the way!
  23. Dec 20, 2020 at 3:43 PM
    biebs96
    PA
    any updates?
  24. Dec 20, 2020 at 6:25 PM
    mghtyducks93
    Southern California
  25. Dec 20, 2020 at 6:31 PM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Looks great!
    biebs96 likes this.
  26. Dec 20, 2020 at 6:35 PM
    mghtyducks93
    Southern California
    Thank you! Used your write up a bunch too to help me
    RobertD likes this.
  27. Dec 20, 2020 at 6:37 PM
    BlueRibbon4x4
    Geno
    Awesome. Dig the red!
    biebs96 and RobertD like this.
  28. May 1, 2022 at 3:08 PM
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Hello, Installing puddle lights and definitely want the dimming effect. What connector did you use for the footwell tap? Just a t-tap in the line? Thank you.
    mav7021234 likes this.
  29. May 1, 2022 at 3:25 PM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    I would strongly recommend posi taps.
    Msquare and Saltyhero13 like this.
  30. May 1, 2022 at 4:03 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    I actually removed the little footwell light and installed my own LED strips running off that circut.
    I usually use Posi-taps, although I soldered all those connections.
    I also put an inline connecter close to the mirror in case I needed to remove it.
    0205FD35-0BA7-4525-ACFA-EFEDDAC5C371_zps_7d677cf613a674b20b5bf86b86d794051bc313d8.jpg
    I just bought some of these but I've yet to use any..
    Amazon.com: Nicelux Y3 Compact T Shape 1 Pin Electrical Wire Connectors for 1 Conductor T-tap Connection,Self-Stripping Splice Terminals,Automotive,LED Lighting,Sensor,Car Speaker,Display,Clear,15 PCS : Electronics
    BTW, the universal VLED puddle lights are the way to go..
    UNIVERSAL LED PUDDLE LIGHT (vleds.com)
    3gnu04bz_zpsgecrr1ak_5ab0b9823af943a3dc90e6ae4019d9a6f86264fb.jpg f5xhgddq_zpsk85eh7wh_149b06814723553efce0701d6a9defe3bb03f7b0.jpg
    mav7021234 and panicman like this.
