LED lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by Sctundra14, Oct 29, 2019.
  1. Oct 29, 2019 at 4:07 PM
    Sctundra14
    Sctundra14 [OP] New Member
    Rich
    2014 tundra
    Rocky Ridge Altitude edition
    So I have a 14 tundra sr5 crewmax, put some LED bulbs in the vanity mirror and the dome. Like a knucklehead I touched the pliers to the socket when pulling the dome bulbs, which blew the 7.5 fuse for the dome. After replacing it, my SRS, seatbelt, and slip light are all on. Key fob won’t unlock the truck, nor can I lock all doors with the key. Disconnected the battery, replaced the fuse again and put all the old bulbs back. Reconnected the battery and same thing. Any suggestions? I have a decent code reader and multimeter coming tomorrow. Any help would be awesome!
  2. Oct 29, 2019 at 8:00 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Check the 7.5a ecu fuse under the hood fuse box.
    I would check all the fuse while you're at it.
