Led lights
Discussion in 'Lighting' started by TundraRunner481, Feb 2, 2018.
  1. Feb 2, 2018 at 1:56 PM
    TundraRunner481
    TundraRunner481 [OP] Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Hi everyone, swallowing my pride here a bit. Went to change to led interior lights and ran into a snag. I thought can bus lights would work and apparently they don't. The minute I tried one it popped a fuse and now no interior lights work. I tried replacing what was called cargo lp in the exterior fuse panel and still nothing. I thought it would be one of the 7.5 amp fuses but can't find it. Any help would be appreciated, 2018 SR5 if that helps.
  2. Feb 2, 2018 at 3:00 PM
    TundraRunner481
    SB
    So. Oregon
    Cool I hope that is all it is! I will check after work, thank you. Wonder if it being can bus popped it?
    SouthBoundSteve likes this.
  3. Feb 2, 2018 at 3:14 PM
    TundraRunner481
    SB
    So. Oregon
    I started with the back ones, I was really careful not to disturb anything and not to be rough pulling the bulb out.
  4. Feb 2, 2018 at 3:22 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  5. Feb 2, 2018 at 5:53 PM
    TundraRunner481
    SB
    So. Oregon
    For those curious it is actually the interior fuse panel, behind the driver side kick panel. It is also a 10 amp fuse labeled "dome." They maybe changed it for the '18's?
  6. Feb 2, 2018 at 5:56 PM
    TundraRunner481
    SB
    So. Oregon
    In the picture it is the top left fuse below the 7.5. The picture is upside down, so when you go under there and look it will be the bottom right. Thanks #southboundsteve for the pictures, it is weird that they changed it so drastically.
