LED Lightbar behind '19 TRD Pro grille?
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by ryanm, Oct 7, 2018.
  1. Oct 7, 2018 at 2:18 PM
    ryanm
    ryanm [OP] New Member
    Ryan
    Hey folks,
    First post here, thanks for the incredible amount of knowledge on the site. It's helped tremendously as I've started making some customizations to my Tundra. And a shoutout to @lawrenceb for the tips on finding and negotiating on the TRD.
    Since I started dreaming about Tundras, I wanted to cut out the grille to expose a light bar flush with the grille. Yet, of course, the lower portion of the grille houses the cruise control radar module. Are folks with these radar units installing light bars in the upper portion of the OEM grille? I'd much prefer to go flush with the grille rather than put it behind it. And it's be a waste of a light bar to put behind the module. I guess I could go in the bumper, I like like the idea of a 40" rather than a shorter one.
    lawrenceb likes this.
  2. Oct 7, 2018 at 2:23 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    You have a few options. 1st is you can go in the upper portion of the grille. 2nd you can go in the hood bulge. 3rd you can go in the lower bumper valance.
    I personally would not go in the lower grille being that is where the sensor is located. Just my .02
    ryanm[OP] likes this.
  3. Oct 7, 2018 at 3:06 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    You must be a TN guy, Wyatt Johnson Toyota.
  4. Oct 8, 2018 at 12:22 PM
    ryanm
    Ryan
    @Omohundro Heck yeah, Wyatt Johnson was great. I'll drive right past a couple unnamed dealers closer to me in Nashville and Franklin to go to them in the future.
    @Larmand cool great advice. Now I just need to decide between the bumper install and the behind the grille install. Has anyone cut the TRD Pro grille to get the light bar flush with the grille itself?
  5. Oct 8, 2018 at 12:56 PM
    Cfincke
    San Antonio
    You can fit a 40" bar in the bumper and the hood bulge. Both are @Baja Designs lights.
    *Not my truck
  6. Oct 24, 2018 at 5:41 PM
    TundraTXTSS
    TundraTXTSS New Member
    Conroe
    2020 White TRD Pro
    Window Breakage add on Alarm,Wireless Charger. Console Safe, Rear Dif Breather Relocation, Rear Under seat Storage, Hard wire for Radar Detector, Tonnneau Cover, Brake Sensor Protection,SABM with TRD Filter, Tailgate lock, BFG's, LED Running lights.D-3 Tuner.
    Put one in both hood scoops, it's just a matter of time and I bet someone does it.
  7. Oct 24, 2018 at 5:56 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    buy 2 short ones and mount them where you originally wanted to install it by splitting the difference on either side of the sensor. depending on where you live and drive the missing 6 leds wont make a bit of difference for that 3% of the time that the light bar is actually turned on.
  8. Oct 24, 2018 at 6:21 PM
    TunderStorm
    TunderStorm New Member
    Michael
    2018 TRD SR5 CM MGM +
    - Toytec/Eibach 3/1.5 + TC UCAs - Fuel Vapor 18x9+20 w/BFG KO2 35’s - TRD sway bar - Go Rhino nerf bars - badge delete - Bakflip MX4 - ESP storage - Rockford Fosgate 10’s +++ - TRD shift knob - Weathertech front mats - Escort 360 hardwired - Window tint Future mods: N-Fab M-RDS front bumper w/40” Black Series RC Lightbar
    Nice truck. Not a fan of the 19 Pro grills. My vote goes for the LB in the Bulge and/or in the bumper like the truck shown above
  9. May 29, 2019 at 9:18 PM
    Jphan1226
    Jphan1226 New Member
    2019 Tundra trd pro voodoo blue
    So far a 30in rigid light bar and a 20in rigid curve lightbar both in front end
    I have a 20in double stack rigid midnight curve series just a little lower than the Toyota badge rn will raise it to be right behind the badge when I can get new brackets made. And a 30in rigid bar in the lower section. Still get alot of light out impo
    ScooterInNV likes this.
  10. May 30, 2019 at 8:20 AM
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    I put mine in the bumper but agree that behind the grill would be sweet too like Jphan1226 did.
    Seen people put them in the scoops too and it works well. Yet to see the second scoop done but agree it's only a matter of time.
    Personally on the white TRDP with all the black on the front end I prefer the scoops staying black and not having light bars in them...but different strokes for different folks.
  11. May 30, 2019 at 10:01 AM
    Welcome from NY.
  12. May 30, 2019 at 10:50 AM
    Cthulhu
  13. Jun 1, 2019 at 11:52 PM
    k3vinryl3
    k3vinryl3 New Member
  14. Jun 2, 2019 at 12:30 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Behind my pro grill not the new one tho sorry!
    Berdine likes this.
