LED light retrofit
Discussion in 'Lighting' started by Sequoiar, Oct 22, 2020.
  1. Oct 22, 2020 at 2:55 PM
    Sequoiar
    Sequoiar [OP] New Member
    I put these on a 2014 Sequoia. Is there a way to make it so all white LED shows all the time, not the orange turn signal when running lamp is on?
  2. Oct 23, 2020 at 7:19 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    You need the turning led bulb that stay and blink white. Otherwise, no.
  3. Oct 23, 2020 at 7:36 AM
    Sequoiar
    I am not sure what you are talking about. The OEM LED headlight is a sealed unit
  4. Oct 23, 2020 at 7:48 AM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Have a photo of what you installed?
  5. Oct 23, 2020 at 7:56 AM
    BrandonL812
    Brandon
    You didnt specify you had done the oem led headlight.
    So, i assumed you meant headlights retrofit with led projectors.
    Headlight Revolution likes this.
