Led light bar for behind the grill option?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Spielightdude, Sep 16, 2021.
  1. Sep 16, 2021 at 5:20 AM
    Spielightdude
    Spielightdude [OP] New Member
    Joseph
    2019 Tundra TRD off road and towing package
    Hi everyone,
    Looking for options for an led lightbar to go somewhere in the front but keep incognito when not in use.
    Looking at 250.00-300.00 max for it.
    This is all part of my plan for next year.
    Thank you all
  2. Sep 16, 2021 at 5:25 AM
    SDHQ makes some brackets but the options depend on what grill you have.
    Taco-Spike likes this.
  3. Sep 16, 2021 at 6:42 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    panicman and Taco-Spike like this.
  4. Sep 16, 2021 at 6:55 AM
    Taco-Spike
    Two Trucks
    I have the above in the Tacoma and Tundra. Good light output. Good price point, never had an issue after after 4 years of use. Combo bar for both
    The CR brackets are good also #2 post as another option. Diode Dymanics has a 30'' bar with really good reviews and quality, but a bit over your price point.
    panicman and mountainpete like this.
  5. Sep 16, 2021 at 7:34 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    I drilled some holes in the bumper behind the grill and mounted my bar. Sits just a tad low but I have a Baja Designs s8 bar back there so it still throws plenty of light down the road. You can't see it unless you look for it so I like that it's mostly hidden and since I just used the brackets that came in the box with the light it's probably the cheapest you'll get something in that spot for.
    panicman, AZTundra and coldcanuk like this.
  6. Sep 16, 2021 at 7:38 AM
    TRDSPEC
    TRDSPEC New Member
    Diode Dynamics 30" light bar so far working well. Going from having the light bar on to off with only high beams on it's like putting sunglasses on while driving in the dark.
    Quality is there, plus you can reconfigure the lenses in multiple tints or spread patterns to suit your needs. Only minor complaint is the switch that comes with the kit is a little fragile. But most are going to replace that with one that integrates into Toyota dash slots directly for $15. That and there is a little vibration going on with the light that you can see while driving, but that is easly solved by adding support under the light bar in the middle so it makes contact with the bumper. I imagine most that mount to the bumper are going to do this.. Minor stuff.
    Happy with it.
    panicman and coldcanuk like this.
  7. Sep 16, 2021 at 7:45 AM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Cali raised mounts and auxbeam light bar
    panicman, Gravy and mountainpete like this.
  8. Sep 16, 2021 at 7:46 AM
    1794TX
    Steven
    N.TX
    '20 1794
    Also, before you make a purchase, chat with @memario1214. He's on the official vendors list here, and can get you products from quite a few vendors (including products not listed at hotshot's website). Good folks here.
  9. Sep 16, 2021 at 8:09 AM
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    Behind hood bulge but I like it
    panicman likes this.
  10. Sep 16, 2021 at 8:15 AM
    Which one is that?
  11. Sep 16, 2021 at 8:18 AM
    THORYOTA
    THORYOTA God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    Where'd you get your LB?
  12. Sep 16, 2021 at 8:19 AM
    parkerbows
    Jack
  13. Sep 16, 2021 at 8:19 AM
    parkerbows
    Jack
  14. Sep 16, 2021 at 8:21 AM
  15. Sep 16, 2021 at 8:26 AM
    parkerbows
    Jack
    Thats cool. I figured would just try the strip. serves the purpose for me
    Tundra234[QUOTED] likes this.
  16. Sep 16, 2021 at 8:53 AM
    THORYOTA
    Thor
    Asgard
  17. Sep 16, 2021 at 8:57 AM
    parkerbows
    Jack
    No moisture issue at all
      File size:
      180.9 KB
      92
  18. Sep 16, 2021 at 9:01 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Thanks brotha :cheers:
    Also, @Spielightdude looks like there's a few options already that have been dropped in here for you. Any of them tickle your fancy in terms of light bar placement and the "aesthetics" of it? Once we know where you think you want the light bar we can work through options from there!
    1794TX[QUOTED] likes this.
  19. Sep 16, 2021 at 9:05 AM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    2019 Pro Midnight Black Metallic
  20. Sep 16, 2021 at 10:04 AM
    1794TX
    Steven
    N.TX
    '20 1794
    :thumbsup:
    memario1214[QUOTED] likes this.
  21. Sep 16, 2021 at 12:27 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Beesta[QUOTED] likes this.
  22. Sep 16, 2021 at 12:29 PM
    Beesta
    Beesta New Member
    Jay
    Loudoun County
    Its actually black, its just shinny. Thanks
  23. Sep 18, 2021 at 10:32 AM
    Spielightdude
    Joseph
    I have the stock grill for an SR5 trim
  24. Sep 18, 2021 at 10:37 AM
    Spielightdude
    Joseph
    For those that have them mounted lower in the main grill area how is the the light throw? I'm looking if possible something that will put.out good light straight out as I do plan on doing hood bracket mounted ditch lights for side lighting as this progress.
    My main thought is when I am in a call from my FD I vol. at sometimes we get paged out for down powerline and trees calls.
    In the dark and in any sort of bad weather even with highness it can be damn near impossible to see things like that.
  25. Sep 18, 2021 at 11:45 AM
    TRDSPEC
    TRDSPEC New Member
    With 30" in lightbar with amber driving lenses in the lower opening the throw is better than the stock high beams.
    That said, due to reflectivity of dust or vapor in the air, amber is probably better mounted low and white higher up on the vehicle.
    Edit: I live out where it is pitch dark. Have the the DD Max fogs and the DD 30" inch lightbar again with driving lenses. And I have to say when I turn them off and just run the highbeams its as if I went to driving with sunglasses on. Very happy with the output for dark rural roads with lots of critters running around.
  26. Aug 4, 2023 at 7:39 PM
    ShawnTRD
    ShawnTRD New Member
    Shawn
    Don't know if your still active around here, but can you show me what you did to support the bar, and how it's holding up?
  27. Aug 4, 2023 at 9:07 PM
    Toyotaguy1654
    Toyotaguy1654 New Member
    2018 Tundra 5.7L
    anybody running strobes on their tundra or made their factory lights stroibe lights with a flasher or whatever its called
