LED interior upgrade popping "Dome" fuse all the sudde
Discussion in 'Lighting' started by Cement, Dec 24, 2019.
  1. Dec 24, 2019 at 9:42 AM
    Cement
    Cement [OP] ...
    2019 Cement Trundra TRD
    Hi guys.
    2019 SR5 + Headlight Revolution LED interior upgrade kit = all good for about 6 months. However, last week the 10a "dome" fuse popped killing the interior lights. I replaced it with another 10a fuse and all was good until last night, when it popped again.
    Any thoughts on why all the sudden? Any suggestions on how to remedy? Any concerns going with a 12a or 15a fuse instead?
    Thanks in advance.
  2. Dec 24, 2019 at 10:42 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    The new bulbs are likely contacting the aluminum shroud that's inside the dome or map lights. Pull the fuse, remove the bulbs and open up the holes in the aluminum a little bigger. Replace the fuse and you should be okay.
    Cement[OP] likes this.
  3. Dec 24, 2019 at 10:54 AM
    Cement
    Cement [OP] ...
    Ahh good thinking. Will do and thanks!
