Led interior lights
Discussion in '2.5 Gen Tundras (2014-2021)' started by 3RsDad, Feb 8, 2017.
  1. Feb 8, 2017 at 7:54 PM
    3RsDad
    3RsDad [OP] New Member
    Roger
    17 Tundra TRD OR
    this has more than likely been been discussed but I'm going to pile on. I just put in my JStar LEDs and am very happy with the outcome. Here's the thing, do your best to remove the bulb without taking out the aluminum shield under the cover. If you do bend it or feel you have to remove it, my recommendation is to throw it on the ground and beat it with something solid! I'm a very patient person when it comes to mechanical issues but after 3 attempts I realized there was really no difference with the bezel in or out. You will however may want to apply some quality tape on one side of the cover edge to take up some space ( about .030) as the near silent rattle might wake up the voices
    NewImprovedRon likes this.
  2. Feb 8, 2017 at 8:03 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Feb 9, 2017 at 2:32 AM
    3RsDad
    Roger
    17 Tundra TRD OR
    Hahahahaha, that is funny. I've had my "rock jockey" moments! More than I want to admit:frusty:
  4. Feb 9, 2017 at 1:08 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I had the same problem with the reflector bowls in my truck as well. Ended taking them out and saving them in case someone in the future wants to put the halogens back in it. I did save the halogens, btw. You're correct in saying that there was minimal/no difference with the reflector bowl in or out.
