LED hum
Discussion in 'Lighting' started by HBdirtbag, Mar 15, 2017.
  1. Mar 15, 2017 at 6:37 PM
    HBdirtbag
    HBdirtbag [OP] New Member
    Walnut Creek, CA
    2017 limited cm
    I did XB's in the fogs, and LED's in the interior domes. I now have a hum from the radio at times, i'm thinking it's the inside lights, but was wondering before I started replacing things, if anyone had the same issues.
    I used these for the interior:
    https://www.amazon.com/gp/product/B0186P1MUW/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
    For Shits and Giggles, I ordered these to see if they operated differently (havne't put them in yet):
    https://www.amazon.com/gp/product/B01KGSVMIY/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
  2. Mar 15, 2017 at 7:30 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Hmmmm...
    Is your audio setup completely stock?
  3. Mar 15, 2017 at 7:32 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Easy way to diagnose is to remove the interior lamp fuse and see if it goes away! I don't think it is related to the leds but only one way to find out.
  4. Mar 15, 2017 at 7:41 PM
    I would be researching Electro Magnetic Interference, or EMI and the effects LEDs do to digital radio signals.
    NewImprovedRon likes this.
  5. Mar 15, 2017 at 8:12 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    I'm familiar. Was just curious if anyone had the issue and had switched to a different bulb
  6. Mar 15, 2017 at 8:18 PM
    HBdirtbag
    Walnut Creek, CA
    2017 limited cm
    Yea
    Will remove fuse tomorrow :)
  7. Mar 15, 2017 at 8:19 PM
    A lot of JK Jeep people try the cheaper bulbs that you plug in and have this happen.
  8. Mar 15, 2017 at 8:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    No issues with that on mine.
  9. Mar 16, 2017 at 4:29 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Keep us updated! Good luck!
  10. Mar 16, 2017 at 7:19 AM
    Mike Tread lightly.
    south carolina
    LEDs use a driver to turn the led on. If the drivers are cheaply made they will give off a emi or feedback into system(vehicle) making what you hear is noise.
