LED hitch mount light
Discussion in '2.5 Gen Tundras (2014-2021)' started by Glamontagne, Oct 12, 2021.
  1. Oct 12, 2021 at 6:08 PM
    Glamontagne
    Glamontagne [OP] New Member
    Gary
    NH
    2024 Midnight Black Crew Max Limited TRD
    I bought a hitch mount reverse light/brake light/turn signal online. It uses the 4 wire trailer wiring. Has anyone figured a way out to wire this better? My last truck, I could unplug from the back of the bumper and put in a splitter. I’d like a cleaner look.
    Thanks,
    Gary
  2. Oct 12, 2021 at 6:18 PM
    biebs96
    PA
    Contact @Puppypunter he makes plug and play wire taps. I bet he could hook you up.
    Taco-Spike and Puppypunter like this.
  3. Oct 12, 2021 at 6:48 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Any pictures? I’ve been looking at some of these.
    biebs96 likes this.
  4. Oct 12, 2021 at 7:00 PM
    You could use this, just unplug it from behind the bumper and plug it it and zip tie the extra wires.
    CURT 55384 Replacement Vehicle-Side Custom USCAR 4-Pin Trailer Wiring Harness, Black https://www.amazon.com/dp/B0009FJ38Q
    AZTundra and biebs96 like this.
  5. Oct 12, 2021 at 9:03 PM
    Puppypunter
    Puppypunter New Member
    Johnny
    Denver, CO
    2019 Tacoma
    As mentioned, the trailer connections are definitely on way to go. The light you bought, does it have independent inputs for turn signals and brake? Because the only real downside to using a trailer wiring tap is that the turn and brake are combined signals. If you want separate taps, I can definitely help you out there. We can grab everything you need from behind the taillights, all plug and play. Feel free to shoot me a PM if you need anything (including just help with a trailer wiring tap).
    NewImprovedRon and biebs96 like this.
  6. Oct 13, 2021 at 5:24 AM
    Glamontagne
    Gary
    NH
    This is what I bought on eBay.
  7. Oct 13, 2021 at 5:25 AM
    Glamontagne
    Gary
    NH
    That looks like a good option. I’ll check it out. I am going to see if I’m able to unplug from behind the bumper before making the purchase. Thanks!
  8. Oct 13, 2021 at 5:47 AM
    You can. That's how I hooked up my light.
    NewImprovedRon likes this.
  9. Oct 13, 2021 at 8:52 AM
    Puppypunter
    Johnny
    Denver, CO
    2019 Tacoma
    Yeah, looking at that, I think you’d be good with a trailer connection. I haven’t started getting into those… yet o_O But since they are using a 4 pin, and it independently drives the turn signals, there is some internal logic capable of separating the two in that unit.
  10. Oct 13, 2021 at 11:39 AM
    Glamontagne
    Gary
    NH
    ok, cool. I’m fairly technical. Just don’t want to mess anything up. Is it easy to take apart?
  11. Oct 13, 2021 at 4:16 PM
    Yes
    Unplug and connect......5 minutes and done.
  12. Oct 13, 2021 at 4:25 PM
    chingyeunglo
    chingyeunglo New Member
    My DIY LED hitch lights.
    mav7021234 likes this.
