LED Headlights not bright enough 2018 tundra
Discussion in 'Lighting' started by 1bmpskir, Dec 31, 2017.
  1. Dec 31, 2017 at 11:20 AM
    1bmpskir
    1bmpskir [OP] New Member
    eric
    2018 SR5 TRD
    Lift level 295/70/18
    Recently traded in my 2012 tundra for a 2018 that has Led headlights, my 12 had stock headlight that were so much brighter than the new 18 LED'S. anyone else experience this ?
    Y0TA PR0 likes this.
  2. Dec 31, 2017 at 11:21 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Nope in fact the opposite....the leds on my 18 are miles brighter than my 13 was
  3. Dec 31, 2017 at 11:22 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Welcome! I thought led would be more output.
    Let’s see pictures of your ride
  4. Dec 31, 2017 at 11:24 AM
    Vernsstar
    Vernsstar New Member
    Mark
    2018 Tundra DC Limited TRD 4X4
    My led headlights are much brighter than
    The traditional headlights that were on my 2015 Tundra
  5. Dec 31, 2017 at 11:25 AM
    1bmpskir
    eric
    2018 SR5 TRD
    Even with adjustment turned all the way up no-one flashes me
  6. Dec 31, 2017 at 11:33 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Is that how you're gauging brightness? If someone flashes you?
    I have read they 18 LED lights aren't that great but you're the 1st to say they are dimmer than previous generations.
    yosh2000, FlashCulprit and Y0TA PR0 like this.
  7. Dec 31, 2017 at 11:39 AM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    Compared to 3rd party bulbs the output on the stock LED is not as focused and too short IMO. However, it's definitely bright enough.
    A lot of people were ranting and raving on the GTR Ultra LEDS as it fixes the height issue and has a super clean hot spot but I'm a lowly 2nd gen owner, and this is all at the mouth of a friend with a 2018.
    This should certainly not be an indicator of how bright your headlights are. At full tilt toyota had designed these to not blind other drivers so you wont get that effect (plus, it's a safety issue, I would strongly suggest this not be a goal).
    HID's are giving way to LEDS for a reason. The days of people putting HID's in stock housings and blaring down the street will be dead because it doesn't work. Much like HID's, LED's have requirements to focus output in a specific manner requiring housings designed around them.
    Backslider and Pudge like this.
  8. Jan 2, 2018 at 10:02 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    My 2018 LED headlights put my stock Platinum headlights to shame. I even swapped bulbs in the stock headlights to Sylvanias best and they were still much worse than the 2018's. Did you adjust the level so they are not pointed at the ground?
