LED Headlight upgrades
Discussion in 'Audio & Video' started by jarivero0312, Aug 3, 2018.
  1. Aug 3, 2018 at 5:21 PM
    jarivero0312
    jarivero0312 [OP] New Member
    2002 tundra limited
    I just bought a new tundra for the cheap since it needed a new engine. The original engine had 240k miles. I dropped a newer one with 105k. The first thing I noticed was that the headlights were yellowed out and dim. I just bought new assemblies and I need help finding the right led kit. I was just wondering what you guys have done.
    LaaMahTundra likes this.
  2. Aug 3, 2018 at 5:43 PM
    reaper3030
    reaper3030 New Member
    Charles
    Tundra 2018 SR5 4X4 Concrete Crewcab
    Rock star wheels, off road tires, LED interior lights, LED fog lights, and .50 cal antenna.
    I’m in for info as well.
  3. Aug 3, 2018 at 5:44 PM
    Riskyguy
    Riskyguy New Member
    Stewart
    2018 Tundra SR5 Crewcab
    You will get more responses if you post in the "Lighting" forum.
  4. Aug 3, 2018 at 6:06 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    For a 2002 I think buying a set with clear lenses and doing an LED or HID Retrofit is your best bet for looks and light output. Just be sure to get them sealed up well
  5. Aug 3, 2018 at 6:18 PM
    Pudge
    CT
    Be aware that 2 door, extra cab and double cab have different headlights. But get something like this...
    And open them up and add something like this...led or hid
  6. Aug 3, 2018 at 6:37 PM
    jarivero0312
    2002 tundra limited
    Thanks for the replies
  7. Aug 3, 2018 at 7:55 PM
    Pudge
    CT
    If you already have the housings you're half way there. Don't just add LED bulbs though. Get the projector and do it right. The scatter of LED bulbs in the stick reflector housing will be blinding to oncoming traffic. HID projectors fo cost less than LED
  8. Aug 4, 2018 at 10:49 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I concur with that, do the projector upgrade. Not only will you avoid blinding people who you are behind on the road but your light output will be better with the focus.
    I did HID with a kit from the retrofit source, came out really well. My lights spread across 4 lane freeways, they shine very far ahead and they don't blind people (lowered hatchbacks maybe). There were not as many LED kits at the time but if they run cooler I would go that route.
