LED headlight suggestion for Sienna?
Discussion in 'Other Toyota Vehicles' started by Zero One Actual, Dec 9, 2019.
  1. Dec 9, 2019 at 5:49 AM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    I have a 2015 Sienna minivan (insert laughter here) and I want to change to LED headlights and high beams.
    I don’t know anything about LED companies out there for this and was wondering if anyone had any suggestions based on previous experience?
    Thanks I’m advance.
  2. Dec 23, 2019 at 3:47 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Zero One Actual[OP] likes this.
  3. Dec 23, 2019 at 5:24 AM
    bfd300
    bfd300 New Member
    Auxbeam. Love mine
  4. Feb 29, 2020 at 7:05 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    I like these: https://www.toptierautoparts.com/index.php/product/t2-led-headlight-conversion-kit/
    because they have one of the smallest rear end allowing for more clearance. many these days get installed with a closing dust cap, removes some of the anxiety of, "will it fit?" it has a metal base plate so once you install it, you can rotate the light a bit to help fine tune your 'hot spot' allowing for maximum brightness and minimum shadowing.
