LED Headlight Bulbs
Discussion in 'Lighting' started by DI1794, Feb 13, 2019.
  1. Feb 13, 2019 at 4:57 PM
    DI1794
    DI1794 [OP] New Member
    Bill
    2019 Silver 1794
    K&N Cold Air Intake Remote Locks and Start
    I just bought a 2019 Tundra 1794. Does anybody have any opinions or advice on aftermarket LED headlight bulbs?
  2. Feb 14, 2019 at 4:11 AM
    Tunder White
    Tunder White New Member
    Your truck did not come with led?
  3. Feb 14, 2019 at 11:05 AM
    Fundras
    Fundras New Member
    I like this company:
    https://www.online-led-store.com/
    It's run by a couple of local guys close to where I live and I like supporting local businesses. I haven't tried their headlight bulbs but their spot/flood lights are top notch and reasonably priced. On a side note, as is mentioned frequently in other threads like this, LEDs and halogen lamps produce light differently and you may not be able to exactly reproduce the headlight pattern of your halogen bulbs with LEDs. When I was looking into this I found it to be a very polarizing topic. Some people had great results and loved the LEDs, others hated them.
  4. Feb 14, 2019 at 12:27 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    Auxbeam NF-S1. I have them in my headlights and fog lights and produce very good light. Beam pattern is just like stock halogen bulbs. I only had to dip the headlights down 1 click since they're brighter. These bulbs are very good because the Led chips are arranged in the exact location and position as halogen filaments as well as having the reflector cup above the low beam for proper pattern.
    Headlights - Auxbeam LED Headlight Bulbs NF-S1 Series LED Headlights with 2 Pcs of H4 9003 HB2 P43T CSP LED Headlight Conversion Kit 50W 8000lm 6000K Hi-Lo Beam - 1 Year Warranty https://www.amazon.com/dp/B074GZ3S4P/ref=cm_sw_r_cp_apa_i_H4CzCbD3BHNT2
    Fog lights - Auxbeam H11 LED Headlight Bulb NF-S1 Series LED Headlights with 2 Pcs of High Brightness CSP Chips H11 LED Bulbs H8 H9 Conversion Kit 50W 8000lm 6000K Single Beam - 1 Year Warranty… https://www.amazon.com/dp/B07NQ9XMHM/ref=cm_sw_r_cp_apa_i_O6CzCb8J7D8NS
    Dixiescotsman, Winning8 and Fundras like this.
  5. Feb 14, 2019 at 12:28 PM
    Fundras
    Fundras New Member
    Those look great!
  6. Aug 31, 2019 at 11:19 AM
    maedhrosfeanor
    maedhrosfeanor New Member
    2014 Silver Tundra Limited
    Did you need any additional hardware/wiring/resistors to use these? Ive got a 2014 Limited with the stock setup and was wondering...
    Corr2626 and Traveling_Tundra like this.
  7. Aug 31, 2019 at 11:28 AM
    Shephard_Of_The_Tundra
    Shephard_Of_The_Tundra DIY try guy
    Corpus Christi, TX
    2016 Black Tundra SR5 4.6 DC 2WD
    Morimoto 2 stroke H4 LED Headlight Bulb VLEDs 3157ck Amber Triton V6 TurnSignal Auxito LED reverse bulbs OEM Toyota LED smoked fog lights Auxito LED T10 license plate bulbs Auxito LED T10 Side marker headlights LASFIT LED T10 3rd brake light Xenon Depot T10 LED Bed/Brake Lights TRD Off-Road Black/Chrome Wheels Bridgestone Duellers 255/70/R18 Front & Rear TRD Sway bars MBRP Dual side exhaust exits Drop-in K&N air filter TRD air flow accelerator Toyota Rubber floor liners OEM Rear under seat storage box Kenwood DMX7706S head unit TRD Shifter knob Center console organizer tray Dual USB fast chargers center stack
    You should definetly have led highs/lows and drls from the factory, only halogen bulbs are turn signal and side markers
  8. Sep 3, 2019 at 7:07 PM
    Yota100
    Yota100 New Member
    14 Tundra 4x4 97 T100 4x4
    14 Tundra 2.5 kings all around with remote reservoir and adjusters with 700# springs Total chaos bushing style control arms Camburg 1.5 inch lift shackles Coachbuilder polt bushings in leaf springs Bmc and front bumper trimmed 37x12.50x17 toyo MTs 17 inch Icon rebounds +25 offset 5% tint Winjet taillights True dual flowmaster super 40s ARB summit bumper Smittybuilt 12k winch White Knuckle Offroad sliders
    I haven't had the best experience with my aux beam leds installed the correct way but just not bright enough seems duller then my stock halogen my 2500 has some hikarie brand I can't spell it but they are brighter then my aux beams
    wakeboarder likes this.
  9. Sep 3, 2019 at 10:51 PM
    Headlight Revolution
    Headlight Revolution New Member Vendor
    Atlanta, GA
    Auxbeam can be a hit or a miss. We've had some tests where they are good, and others where they are not so good. Those pictures look nice though @TundraTSS19! :) I hope you have good luck with them.
    TundraTSS19 and Yota100 like this.
  10. Sep 4, 2019 at 3:56 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
    Anyone with Aux beam LEDs installed have to deal with state inspections? Has your truck passed with these installed?
  11. Sep 4, 2019 at 6:29 AM
    Atlanta, GA
    Just about any LED bulb replacement will not pass an inspection, as they are not DOT approved for the roads. There are aftermarket headlight housings that are DOT/SAE Approved such as Morimoto and 7" rounds like J.W. Speaker and VisionX, but as far as bulb replacements, the bets are off unfortunately. Just swap over to Halogen when an inspection is coming up and you're golden! As far as legality with police and such, as long as you aren't blinding everyone and driving down the roads with your 6 light bars on, you will be just fine. :) I do know that some states and specific countys may be more strict than others, so it may be best to consult some local shops and such to make sure!
    Vr0ck[QUOTED] likes this.
  12. Sep 4, 2019 at 8:24 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    I remove my lightbar behind the grill currently for inspections (reminds me I have to do that before my sched inspections next week). Funny thing is when I had my stock SR5 grill and the lightbar it passed. With the TRD pro grill they clearly see the lightbar and fail automatically.
    If I end up doing LEDs, ill just add swapping them back to halogen on a yearly reminder.
  13. Sep 4, 2019 at 8:30 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    ^ Your 1794 was devoid of this pleasure?
  14. Sep 4, 2019 at 9:52 AM
    Atlanta, GA
    Will they not pass you if you maybe had a Light Bar Cover? Or is it just technically a Mod? I know my friend just covers his with a plastic cap it came with and he passes every year. :) SR5 Grills FTW!
  15. Sep 4, 2019 at 9:55 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    18+ 1794 all come with the OEM LED headlights
    Toyokuhl likes this.
  16. Sep 4, 2019 at 10:35 AM
  17. Sep 4, 2019 at 11:20 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Having the lightbar behind the grill, I cant easily put a cover on it...at that point ill just disconnect and remove the lightbar for inspections.
  18. Sep 4, 2019 at 11:51 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    what is the reason replacing these?
  19. Sep 4, 2019 at 1:11 PM
    Atlanta, GA
    For replacing the Halogen Headlight bulbs?
  20. Sep 4, 2019 at 1:37 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    no, for replacement of his stock LED HL's. he stated in the OP that he has a '19 1794 and was looking for advice or opinions on aftermarket. why? is the quality that bad in our oem's or is the quality that good in aftermarkets?
  21. Sep 4, 2019 at 2:02 PM
    Atlanta, GA
    I'm not quite sure! Personally I think the Bi-LEDs are fantastic in both performance and with that crispy white DRL bar surrounding the headlights. The only Aftermarket headlight assembly I could recommend would be the Morimoto XB LED Headlights, as they have done an amazing job at not only keeping OEM quality, but they are also DOT Approved and look just gnarly. Other than that, brands like Spyder, Anzo, ProTuningLabs, etc would definitely not be an upgrade over the OEM Bi-LEDs, but more of a loss in quality and functionality.
  22. Sep 4, 2019 at 2:46 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I love the look, and what appears to be quality, of the XB LED HLs but cant justify the jump in price over what i think are very good OEM LED's. I am going to be getting XB fogs for the gf's 4runner and we want to upgrade her HL's to LEDs. @Headlight Revolution any remedies for the 4runner that you guys have, which are an upgrade over OEM?
    Headlight Revolution likes this.
  23. Sep 4, 2019 at 4:28 PM
    Atlanta, GA
    For sure! There are XB LED 4Runner Housings as well, but they are higher up on that price point.
    The other great option for the Low beams would Be either in HID kit or an LED low beam kit. We have both the GTR lighting 55w HID kit in a 6,000k color will do fantastic for the Lows, while matching the XB Fog lights in color as well. The big positive to this kit is that it is backed with a Lifetime Warranty, no questions asked!
    Link: https://headlightrevolution.com/2014-2019-toyota-4runner-gt-hid-kit-low-beam/
    For an LED option, the V.4 is a solid Plug and play bulb that rivals an HID kit in performance and beam pattern, backed with a 2-year warranty. These are also in that 6,000k color field which will be pure white on the road, but Infront of the truck, you will see a very very slight Hugh of light blue to it, almost like the newer BMW, Audi, Mercedes LED Headlights.
    Link: https://headlightrevolution.com/2014-2019-toyota-4runner-sv-4-led-low-beam/
    As for the High beams, the V.4 is the absolute best option for this application, the V.4 really excels here.
    Link: https://headlightrevolution.com/2014-2019-toyota-4runner-sv-4-led-high-beam/
    (Please read the DRL message before purchasing!)
    Hope that helps homie! Just let me know if you have any questions.
    Toyokuhl[QUOTED] likes this.
  24. Sep 4, 2019 at 6:26 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    im going to be contacting you when we are ready to make the purchase... thanks for the help!
  25. Sep 4, 2019 at 6:50 PM
    Atlanta, GA
    You got it buddy! :thumbsup::) Looking forward to helping you out!
  26. Sep 10, 2019 at 10:27 AM
    TundraTSS19
    San Antonio, TX
    So far so good. They've been installed 9 months now and never had an issue.
  27. Nov 7, 2019 at 2:56 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    My experience with trying AuxBeam bulbs in my original housings was a bust. A little better than the halogen bulb but light patterns were crappy and the high beams were really poor. Bit the bullet on the OEM TRD Pro LED housings and they are awesome - well worth the $$$.
    I used the harness from @iHacker and the swap was a breeze. Highly recommend doing the housing upgrade.
    iHacker likes this.
  28. May 2, 2020 at 1:37 AM
    Dixiescotsman
    Dixiescotsman New Member
    Robert
    2019 SR5
    20x9 XD wheels on 35's
  29. May 2, 2020 at 1:38 AM
    Dixiescotsman
    Robert
    2019 SR5
    Just ordered mine. Those look great! How hard was the install?
  30. May 2, 2020 at 5:36 PM
    TundraTSS19
    San Antonio, TX
    All you have to do is pull up a YouTube video from headlight revolution.
