LED headlight bulb fitment with fans?
Discussion in 'Lighting' started by GNX6, Nov 19, 2018.
  1. Nov 19, 2018 at 7:50 PM
    GNX6
    GNX6 [OP] New Member
    2014 Crewmax
    TRD rear sway bar TRD oil cap (adds 25 HP, It said so online)
  2. Nov 19, 2018 at 9:18 PM
    Rica25
    Ricardo
    Tulare
    I had led on my stock housing before switching and they fit just fine
  3. Jan 19, 2019 at 11:30 AM
    strapko
    strapko New Member
    Philippe
    2015 Toyota Tundra Platinum
    18” Method Grid 18x9 285/65R18 Toyo A/T II Trd Pro Grill
    @GNX6 I’m looking to do that exact set up! Did you end up doing it??
  4. Jan 19, 2019 at 1:06 PM
    TundraTSS19
    TundraTSS19 New Member
    San Antonio, TX
    2020 Tundra TSS SR5 Crewmax 5.7L
    LED step bar light strips
    The black base that the bulb locks into shold come off Usually when you rotate it 180 degrees you should be able to separate the bulb from the black base. Install the base and clamp it. Install the boot and seat it properly and then insert the bulb and rotate 180 degrees to lock it in. Afterwards make sure the bulbs are a I'm properly with the high and low beams.
  5. Jan 19, 2019 at 5:57 PM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Try Morimoto 2.0
    $120.00 at Theretrofitsorce.com
    I bought them for my fog lights but they also have them for your headlights.
    Great reviews
  6. Jan 20, 2019 at 11:48 AM
    GNX6
    2014 Crewmax
    I couldn’t get the rubber booties over the fan body. I was going to order a new set and then soak them in hot water to see if I can slip them over but have not bothered with it yet.
  7. Jan 20, 2019 at 11:51 AM
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    Are you sure that the fan body does not separate from the socket that locks into the headlight?
