LED DRL headlight upgrade
Discussion in 'Lighting' started by Tundras_Over_Everything, May 24, 2020.
  1. May 24, 2020 at 4:52 AM
    Tundras_Over_Everything [OP] New Member
    Anthony
    2019 Toyota Tundra SR
    FFC04888-C7C0-4D8E-8F43-F371C0C94977.jpg ACE1716C-DE43-4943-8C9A-BFBC1517E276.jpg E0C55F09-18CA-4CE2-B5B5-45EA4CC3AB38.jpg I have a 2019 Tundra SR model and with factory OEM headlights with leveling adjuster and LED strip. I recently purchased 2019 Tundra sequential LED DRL projector headlights from Specdtuning. The wiring is not the same but the headlight itself fits perfectly in the space for the head lamp. After plugging the connectors that I was able to match up I realized all but the main DRL LeD tube lights up. Can anyone help me with what wiring additions I need to make these work for me. I purchased a conversion harness from @Headlight Revolution bur not sure I even needed it. Anything will help!!! Thanks
  2. May 24, 2020 at 5:13 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Need to wire the positive wire of the drl to something to trigger it. Mines on my ignition fuse.
  3. May 24, 2020 at 5:18 AM
    Anthony
    I’m new to all of this sorry if the questions sound ridiculous! How do I find the positive wire of the DRL? What area will the wire be coming from on the headlight? Ex.turn signal plug, parking light plug? @xtyfighterx
  4. May 24, 2020 at 6:16 AM
    TigOlTundra
    TigOlTundra New Member
    Tig
    New Hampshire
    2010 SR5 TRD Off-Road, DC 4.6L Slate Metalic
    Hypertech Interceptor, Old Man Emu 612 Front Coilovers and Rear Sport Nitrocharger Shocks, Mamba M19 Wheels, Falken Wildpeak AT3W Tires, Tyger Auto Blades, EAG Grill with lights, DNA Motoring LED/DRL Smoked Headlights, Tubro SII LED Highs and Lows, DTMoto LED Tube Smoked Tail/Brakelights, Alla Lighting Rear Signal LEDs and Reverse LEDs, Note Smoked Third Brake/Cargo light, Plasti-dipped badges, Back-rack, Husky X-Act Contour Floor Liners, OEM Rear Underseat Storage, Colormatched Land Cruiser "Toyota" Grill Badge
    I just installed some headlights very similar on my 2010 and got too frustrated trying to wire the DRL LED tubes to function as DRLs so I just t-tapped into the marker lights instead so they turn on with my lows. Should be a red and black or white and black that come from the headlight. White is hot, black is neutral. If you wanted them to function as DRLs then you need an add-a-fuse to piggyback the IGN fuse so they turn on when you turn the truck on. I couldn't find the right add-a-fuse from my local auto store and got impatient so I didnt order one online.
  5. May 24, 2020 at 6:22 AM
    Anthony
    Thanks I think I’ll go that route! Just need help identifying which wire I need to use(which wire will light up the LED tube)
  6. May 24, 2020 at 6:26 AM
    Rotaryphoneuser
    Rotaryphoneuser New Member
    Ontario. Canada
    2018 Cement CrewMax
    There is a video on YouTube. There is a one wire that hooks into fuse panel. I can't recall which video but I saw couple of them.
  7. May 24, 2020 at 6:38 AM
    TigOlTundra
    Tig
    New Hampshire
    Obviously my 2nd gen isnt going to be the same as the 2019 but the ones I ordered came with no wiring harness or instructions for the led drl tubes so I sort of had to do the legwork to sort it out. On the headlights I installed there were existing plug and play harnesses for the highs, lows, and turning signal. Then there were two loose unharnessed wires at the bottom (1 black and 1 white) that were for the led drl tubes. Those are the ones you want to tap into the marker light wires. On my marker lights it was white to green and black to black and white. Hope this helps
  8. May 24, 2020 at 6:47 AM
    xtyfighterx
    Ty
    North Idaho
    Do you have an actual pic of the back of the headlight?
    didn’t come with any instructions or diagrams?
  9. May 24, 2020 at 6:51 AM
    TigOlTundra
    Tig
    New Hampshire
  10. May 24, 2020 at 6:52 AM
    xtyfighterx
    Ty
    North Idaho
    I see yours clearly on the pic he posted I don’t see those at all OP if you have a real pic of the back of your lights post it let us take a look.
  11. May 25, 2020 at 3:51 PM
    HaitianKnight007
    HaitianKnight007 New Member
    STANLEY
    North Carolina
    2007 Red Limited Crew Max
    FAHREN LED HEADLIGHTS
  12. May 25, 2020 at 11:01 PM
    xtyfighterx
    Ty
    North Idaho
  13. May 26, 2020 at 5:19 AM
    HaitianKnight007
    STANLEY
    North Carolina
    I don’t believe so, Morimotos are around $900. The ebays are like $225. Morimotos look like they are higher quality without as much or any mods involved.
  14. May 26, 2020 at 6:11 AM
    xtyfighterx
    Ty
    North Idaho
    My bad I only saw the link for the Morimotos.
  15. May 26, 2020 at 8:36 AM
    HaitianKnight007
    STANLEY
    North Carolina
    No worries I’m learning myself about these light options. Lmao
  16. May 28, 2020 at 10:49 PM
    iRenaissanceMan
    iRenaissanceMan New Member
    I saw a few reviews of generic headlights and they're pretty terrible - yellowing in <1year, LED going back after 3 months, condensation in headlight. Just really bad stories. I'm curious if maybe they're user error? I'd love to do the Gen2 update to Gen2+ with the Sequoia TRD Grill and "cheaper" headlights. Trying to keep the update to less than 1k.
    HaitianKnight007 likes this.
  17. May 29, 2020 at 5:00 AM
    The Morimoto XB's are alot cheaper than the Sequoia conversion.
