led daytime running lights that do not cost $100?
Discussion in 'Lighting' started by andy9743, May 19, 2017.
  1. May 19, 2017 at 8:45 AM
    andy9743
    andy9743 [OP] New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
  2. May 19, 2017 at 10:32 AM
    strosek7
    strosek7 New Member
    2016 Black Tundra SR5 DC
  3. May 19, 2017 at 11:47 AM
    Have local auto stores round you? AutoZone Orielys Advance Auto...check out sylvania zevo ultra bright LEDs ambers come in pair 34$ resistor box pair 18$
  4. May 19, 2017 at 12:01 PM
    Teriks
    Teriks New Member
    Tom
    Front Range, CO
    2008 Toyota Tundra Limited DC 4x4 5.7
    As some have mentioned, the bulbs themselves will work but it will hyper-flash if you don't use a flasher/resistor. Tons of options on bulb brands - pick whatever you're comfortable with. Personally, I'd make sure the bulb has a high/low setting as the DRL light dims with the headlights on.
  5. May 25, 2017 at 7:19 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Finished my LED / HID conversion today. Resistor is the only way that you can go on both front and rear Amber blinker bulbs. The dimmer feature with head lights on works perfectly.
    Teriks likes this.
  6. May 25, 2017 at 7:22 PM
    JTP
    The Big Black Moose
    superbrightleds.com
    has the complete list of conversion LED lamps for Tundras. EVERY EXTERIOR BULB AND THE 4 RESISTORS (except head lights) was $150.00 total.
    BlueBottle and Teriks like this.
  7. May 28, 2017 at 7:46 AM
    andy9743
    andrew
    nw ohio
    Thanks for feedback. @JTP do you have part numbers for what you used? Looks great!
  8. Jun 10, 2017 at 7:39 AM
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    Are the factory driving/turn signal bulbs (4157NAK) a standard or CK style socket? How can I confirm which I have? 2017 tundra SR5
