LED bulbs? Any advice?
Discussion in '2.5 Gen Tundras (2014-2021)' started by SmoothDog89, Mar 20, 2020.
  1. Mar 20, 2020 at 1:06 PM
    SmoothDog89
    SmoothDog89 [OP] New Member
    Brandon
    2014 White Tundra TSS Offroad 4x4 Crewmax
    6" Fabtech Suspension Lift, KMC XD series Misfit 20x9 +0, Toyo A/T Open Country Extreme 35x12.5R20LT, K&N Performance Intake, Spray-On Bed Liner, Pace Edwards Full Metal JackRabbit Tonneau Cover.
    I have a 2014 Tundra Crewmax and recently purchased a set of LED headlight bulbs and fog light bulbs from a local source in the DFW Texas area. Needless to say I'm not impressed at all, don't get me wrong they work and are brighter than the halogens but I'm needing and wanting as bright as possible on both the headlights and fog lights. I plan on applying some lumin-x amber tint to the fog light lens so I need all bulbs to be as bright as possible. So before ordering some off of Amazon I figured I would ask yall first. are there any recommendations that won't break the bank since I've already spent $180 on a set of headlight and fog lightLED's?
  2. Mar 20, 2020 at 1:19 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    I have supernovas from headlight revolution and they are great. Super Bright and retain the same pattern as halogen bulbs.
    For fog lights I replaced mine with rigid cubes.
    From my experience Lamin-X on Bright LED bulbs does not look good. It makes them a weird green rather than amber or yellow. I tried it on my cubes and ended up taking it off. You will also lose quite a bit of light output.
    If you wanted amber fogs then your best bet is to get ones that are already amber.
  3. Mar 20, 2020 at 1:49 PM
    SmoothDog89
    Brandon
    Ok good thanks I'll check out those supernovas, are they very bright, require any modifications for install or adjustment for the correct beam pattern?
  4. Mar 20, 2020 at 2:00 PM
    bdpeelgren
    Round Rock, TX
  5. Mar 20, 2020 at 4:12 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have Lasfits in my fogs. They work great. I could not even tell I had fogs on with OEM bulbs.
  6. Mar 20, 2020 at 4:55 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Headlight Revolution has a 20% off sale right now!!!
  7. May 15, 2020 at 4:52 PM
    Bigbird57
    Bigbird57 New Member
    Bought a set of Lasfit turn signal bulbs from an eBay seller. These were the highly touted "switchback" version. Lasfit advertised no hyper flash. Well they hyper flash. Reached out to Lasfit for help. No help because the eBay seller was not an affiliated reseller.
    They admitted the Gen 3 Tundras had an issue with poor performance but has been corrected. You have to love it when a company stands "way" behind their product.
    Rant over.
