LED bulb upgrade question
Discussion in '2.5 Gen Tundras (2014-2021)' started by CTPlatinum, Apr 21, 2020.
  1. Apr 21, 2020 at 5:42 AM
    CTPlatinum
    CTPlatinum [OP] New Member
    2020 Tundra Platinum 4x4
    None Yet
    I have a 2020 Platinum, I plan to switch out the headlights to the 2019+ black TRD headlights and want to upgrade the front blinker and the rear back up bulb. I know that JDM ASTAR work as plug n play, but have been told that if I add any other led bulbs to the truck I will need resistors. Is there any way to change both the front blinker and rear back up WITHOUT adding resistor?
  2. Apr 21, 2020 at 6:00 AM
    Broncoman
    Broncoman New Member
    I upgraded the headlights on my 17 along with changing every other bulb to LED and added LED Fogs and Switchback blinkers. I bought all lights through Headlight Revolution and had to add the resistors to the headlights and blinkers. Totally worth it even with the resistors!
  3. Apr 21, 2020 at 9:03 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Reverse (rear back-up) lights conversion to LED bulbs require no resister...it's a simple bulb exhange. Additional resistance is required only when using LEDs for the turn signals.
  4. Apr 21, 2020 at 9:11 AM
    You will be fine, no resistors with that swap.
    NewImprovedRon likes this.
  5. Jun 3, 2020 at 1:10 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Figured I would post on this thread. My HD camera comes on when I hit the brake, and also causing noise interference. The audio tech said it could be my led reverse bulbs causing the problem. I really don't need led bulbs as I got leds in my bumper that are super bright. Anyone know what might be causing this. Thanks
