Led bulb swap question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Rockanock, Aug 11, 2019.
  1. Aug 11, 2019 at 9:06 AM
    Rockanock
    Rockanock [OP] 21 Chevy 2500
    So I want to put LED bulbs in my cargo light, back up lights, and license plate lights. Is this just a simple bulb replacement or is their more to it. And can you point me in the right direction for the bulbs.
  2. Aug 11, 2019 at 9:58 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Lots of people using Headlight Revolution and/or VLEDS. Search and you'll find plenty of info on it.
    Ajkkane likes this.
  3. Aug 11, 2019 at 10:41 AM
    Those are just a simple swap.
  4. Aug 11, 2019 at 10:52 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Simple swap like stated above. Just be careful with the dome light. Blows the fuse quickly if you touch both connections.
  5. Aug 11, 2019 at 11:19 AM
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    Simple swap. I just replaced the same bulbs. VLEDS is the way to go.
  6. Aug 11, 2019 at 12:23 PM
    Rockanock
    Thank yall
  7. Aug 11, 2019 at 5:58 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
  8. Aug 11, 2019 at 6:56 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Simple bulb swap. I highly recommend JDM astar bulbs off Amazon. I have had them for years and they work great and are bright. There are a lot of premier bulbs available out there but I just can't justify the cost.
    nvrgvup444 likes this.
  9. Aug 11, 2019 at 6:59 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Simple swap. There's a lot of YouTube videos on how to do it. I bought some SiriusLED on Amazon as well as some Chinese brands for my other car. Can't tell the difference in brightness. A plastic part tool and packaging tape would be helpful.
  10. Aug 11, 2019 at 7:01 PM
    Vleds. Great products and excellent customer service. :thumbsup:
  11. Aug 11, 2019 at 8:28 PM
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    So easy just take your time. I even put JDM in my camper. Can't beat the cost.
    Pudge[QUOTED] likes this.
  12. Aug 11, 2019 at 8:37 PM
    Pudge
    CT
    I have the JDM astar bulbs in every spot I could in my truck except brake lights and those will be coming soon when I get some spare cash. I have not had any burn out or show up non functioning. I find them to be extremely bright with no flickering. They perform as well as some top dollar bulbs I have used in the past at a fraction of the price. Can't go wrong
    nvrgvup444[QUOTED] likes this.
  13. Aug 11, 2019 at 9:34 PM
    fundratss
    fundratss Send it!
    Joe
    Colorado Springs
    2016 Magnetic Grey Tundra TSS
    Toytec 2.5” Coilover boss suspension 3/1 lift w/camburg uca’s Morimoto xb headlights Morimoto fog Rough country grill 2 RC blacked light bars Volant air intake system Rear air bags (for towing) I’m sure there’s more but I’m lazy
    I went the eBay route and my bulbs are still goin strong and bright
  14. Aug 12, 2019 at 4:35 AM
    Drew C
    Drew C New Member
    I swapped the license plate lights and back up lights. Both are much better but I may actually put the plate lights back in tho. The led bulbs are so bright there's a lot of glare on the camera from them at night. Almost cancels out the improvement in the back-up lights.
    Pudge likes this.
  15. Aug 12, 2019 at 8:34 AM
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    I did the same thing and actually found that the stock bulbs actual cause more glare than the LEDs! I had 3 LED bulbs that I grabbed from Amazon (one on either side and a third pointing straight out). I ended up wrapping black electrical tape around it to block out some of the LEDs and it dimmed out a bit, but ended up with a blueish-purple tint and I was concerned about the heat. Put the stockies back in and they cause more blooming on the backup camera. I'm still trying to find a dimmer LED option.
