LED bed lights
Discussion in 'Lighting' started by Dirty Girl, Mar 24, 2021.
  1. Mar 24, 2021 at 8:20 AM
    Dirty Girl
    Dirty Girl [OP] New Member
    Scott
    North Richland Hills, Texas
    2017 black Tundra TSS
    3 in leveling kit, bigger tires and wheels
    I’ve owned my truck just over 3 years now and seems that both led lights in my bed don’t work. Any help
  2. Mar 24, 2021 at 9:25 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Are they the Toyota installed ones or aftermarket? Any photos of them? Could just be a loose cable somewhere.
  3. Mar 24, 2021 at 12:05 PM
    Dirty Girl
    Scott
    They are the ones installed by Toyota
  4. Mar 24, 2021 at 12:11 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'm not sure how they wire those ones up. If they run through a separate fuse you could have a blown fuse under the hood. How do they operate normally? Do they come on with a button or when you open the tailgate?
  5. Mar 24, 2021 at 3:17 PM
    Dirty Girl
    Scott
    They come on by door opening and alarm unlock. I think it’s a splits off from the tail lights.
  6. Mar 24, 2021 at 4:48 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I think so too. Can you get under the rear where the lights are attached to the bed and see if you can follow the wires to the tail lights and see if you have a loose connection or cut wire ?
  7. Mar 24, 2021 at 8:00 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    NewImprovedRon and 1lowlife like this.
  8. Mar 24, 2021 at 10:09 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum..
    Factory bed lights should be tied into the cargo light circuit..
    If your cargo light switch is set on 'door' then it will come on with the unlock or door open.
    If your cargo light switch is set to 'on' the bed lights should come on no matter what, but will time out after a few minutes.
    If your cargo light switch is set to off, they won't come on no matter what.
    Is your cargo light working properly?
    Look at @TucsonTundra1794 instructions.
    I used those very instructions to install my OEM bed lights in my 2014 SR5.
    It may just be a bad connection in the kick panel that taps the bed lights into the cargo light circuit.
    The wires are very small and a bad connection in a t-tap or posi-tap connector is probable.
    I had this issue last week with my Amp steps.
    They've worked flawlessly for 4 years, but out of the blue developed a bad connection in the driver's door.
    They worked with every door except the driver's door.
    Dug out my old AMP install instructions, found the right wire in the kick panel, replaced the t-tap with a posi-tap connector, and that fixed it...
    Good luck..1LL
  9. Mar 25, 2021 at 9:22 AM
    Dirty Girl
    Scott
    Thank you both for helping me. I’ll let you know what I find.
  10. Mar 25, 2021 at 9:50 AM
    Alex261
    Alex261 New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I would love to add those. Any idea of what the cost of dealer install would be for everything?
  11. Mar 25, 2021 at 11:43 AM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Lights are fairly cheap but you'd have to check with your local dealer to get install price.
  12. Mar 25, 2021 at 3:27 PM
    Dirty Girl
    Scott
    They run like $80 each.
  13. Mar 25, 2021 at 9:32 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  14. Mar 25, 2021 at 9:34 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    I have the same issue
