LED bar-wiring question
Discussion in 'Lighting' started by vroomevo, Jun 25, 2020.
  1. Jun 25, 2020 at 4:53 PM
    vroomevo
    vroomevo [OP] New Member
    Los Angeles CA
    Hello, this is probably very stupid question.
    i have 2019 tundra sr5 with oem fog light, i am getting aftermarket front bumper, will be losing oem fog light. if get aftermarket 3 to 4 inch fog light(that comes with wiring kit), can i just connect to oem wire and use oem switch? or do i have to use wiring kit that comes with the light?
    thank you for your help.
    stay safe.
  2. Jun 25, 2020 at 4:57 PM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    You can get connectors on Amazon for like $10 that will plug into the factory plugs. You can then connect those to your lights so you don’t have to cut up the factory wiring and still have a disconnect.
    I’ve got rigid SAE pods I put on my Tacoma and just used an adapter to plug them into the factory wiring
    Tundyfundy likes this.
  3. Jun 25, 2020 at 5:05 PM
    vroomevo
    Los Angeles CA
    thank you for the quick reply. do you know what plug? i have searched and couldn't get beyond H11 connector.
  4. Jun 25, 2020 at 5:44 PM
    shellshock
    Iowa
    2019 TRD PRO
  5. Jun 25, 2020 at 8:12 PM
    vroomevo
    Los Angeles CA
    Awesome. Thank you for your help!
