LED add on
Discussion in '2.5 Gen Tundras (2014-2021)' started by tacouser, Apr 17, 2016.
  1. Apr 17, 2016 at 2:48 PM
    tacouser
    tacouser [OP] New Member
    Chicago
    2015 SR5 Tundra Dbl Cab 4X4
    Bilstein 5100 rear, Klein train horns! Swing Case, Tekonsha P3 brake controller, Bed LED's, Weathertech window visors and floor mats,Retrofit Source Fog Lights, Bakflip cover, Ford Rapter hood leds, Hellwig rear sway bar
    I hate this truck.......All I do is want to add things to it.
    Newest add on's. More lighting.
    1G3-TRD likes this.
  2. Apr 17, 2016 at 3:08 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Looks good. What lights did you use in the grill?
  3. Apr 17, 2016 at 5:13 PM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
    Er Mer Gerd I love led's
  4. Apr 17, 2016 at 6:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looking good
  5. Apr 18, 2016 at 8:01 AM
    tacouser
    Chicago
    Correct the leds in the hood are from Superbright. Eziest mod ever. Thanks to the others who had a wtite up on it.
  6. Apr 18, 2016 at 8:15 AM
    CaptObvious
    CaptObvious New Member
    Patrick
    2015 Black Tundra SR5 Crewmax TRD
    Those lights on the Fab mount look great...that is exactly what I am looking at. How did you mount/wire them?
  7. Apr 18, 2016 at 1:05 PM
    ToyotaTundraMike
    2015 Tundra
    Lights look great! Where did you get the bar that you mounted them on?
  8. Apr 19, 2016 at 5:39 PM
    tacouser
    Chicago
    The light bar is from NFab. The leds are from Pro Comp.
    The leds come with a complete wire harness, relay, switch. I just routed all the cable behind the grill, the harness is actually way to long. Then ran the switch wiring to the fire wall and poked it thru to get it inside. I'll take some inside pics when I can
    CaptObvious likes this.
