Leaves in the fender
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundraforlife, Mar 7, 2018.
  1. Mar 7, 2018 at 12:25 PM
    tundraforlife
    tundraforlife [OP] New Member
    Greg
    2016 Tundra TRD Limited Double Cab in Blue
    Hi all. First time posting, but long time Tundra owner. I wanted to let everyone know of a leaf build-up issue I found in my 2016 Tundra Limited. I live in an area with a lot of trees and get leaves all over cowl area. When cleaning them out, with the hood open, I noticed a leaf fall into a gap at the base of the windshield at the drivers fender. Knowing how leaves caught in the lower part of a fender can over time, create rust, I removed the drivers front splash guard, and pulled the fender liner back, and sure enough, I found a ton of leaves. The passenger side did not have any in there though. This is the second fall I have been through with this truck, and both times, I found a lot of leaves. All were packed into the lower rear of the fender. Just thought I would let everyone know.
  2. Mar 7, 2018 at 12:29 PM
    TheBeast The Beach
    yep..I vacuum mine once in a while. plenty of leaves at the bottom behind the wheel well.
  3. Mar 7, 2018 at 12:29 PM
    I just found that same issue when replacing my fender last Saturday. A lot of leaves. All dry as a bone. No rust. 10 yr old Tunny but fairly dry climate.
  4. Mar 7, 2018 at 12:35 PM
    tundraforlife
    Greg
    I live in Ohio, the buckle of the salt belt. Those leaves will hold moisture, salt, crap like crazy.
  5. Mar 7, 2018 at 12:37 PM
    15whtrd
    15whtrd Mr. Blonde
    Just a heads up you can also access this area by opening up the driver or passenger door and pushing the flap out of the way. I check mine every time I wash the truck.
  6. Mar 7, 2018 at 1:32 PM
    This thread again?!?!?? lol
    15whtrd likes this.
  7. Mar 7, 2018 at 1:39 PM
    15whtrd
    15whtrd Mr. Blonde
    I tried to be nice about it. I’ve been trying to be more patient lately
