Leave AC running without key in ignition
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Shadowfax1, Sep 24, 2023.
  1. Sep 24, 2023 at 7:33 AM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    In the new Tundras you can leave the car running and walk away with your keys in-hand and the engine and AC still running. I think it times out after a while which is fine.
    I need this in my 2018 1794.
    I do not have push button start. Physical key and ignition switch.
    I can accept a remote start that turns the car on along with the climate system bacj at whatever on/off and temp setting it was at before the car was last turned off. This would be fine so long as the car also remains locked.
    suggestions?
  2. Sep 26, 2023 at 10:40 AM
    Shadowfax1
  3. Sep 26, 2023 at 11:56 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I have a start-x remote start from Amazon. Install was easy. I've had it since December of 2021. Some people don't like that you have to press your lock button 3 times to get it to start but it doesn't bother me.
    My truck will just turn back on with everything I left on but I don't have climate control, just knobs. i would think it would work the same though? Do your settings normally stay when you restart?
    That start-X can also accept a cell phone module and the annual service is fairly inexpensive last time I looked.
    one thing to note, the low tire light stays on when you remote start until you put the key in and turn it. Might even have to put it in drive then it goes away immediately, normal behavior.
    https://www.amazon.com/Start-X-Remo...t=&hvlocphy=9021834&hvtargid=pla-664993705671
    I know james @ tech12volts also sells a similar unit from a different brand or at least he used to. if he does it might be a better way to go as he is extremely helpful over the phone if you have any questions (got my stereo from him)
