Leather passenger seat noise
Discussion in 'General Tundra Discussion' started by Alex261, Oct 27, 2020.
  1. Oct 27, 2020 at 8:06 AM
    Alex261
    Alex261 [OP] New Member
    Alex
    Boston, Ma
    2024 Tundra Platinum LR
    I have a 2020 Platinum and the slightest bump makes a noise from the vibration of the passenger seat. It’s driving me crazy because I can always hear it when no one is sitting in it. It’s almost as if I had a bunch of stuff in the back pocket but that’s not what it is. If I bang on the side of the seat I can sort of duplicate it but not totally. Any ideas on what it could be or a fix
  2. Oct 27, 2020 at 9:03 AM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    A loose nut behind the wheel
    Cpl_Punishment likes this.
  3. Oct 27, 2020 at 9:06 AM
    Alex261
    Alex
    Boston, Ma
    Behind the wheel ?
  4. Oct 27, 2020 at 9:07 AM
    Think he was joking about you.
  5. Oct 27, 2020 at 9:07 AM
    Did you check if the seat bolts are tight?
  6. Oct 27, 2020 at 9:15 AM
    Alex261
    Alex
    Boston, Ma
    Ha gotcha
  7. Oct 27, 2020 at 9:18 AM
    Alex261
    Alex
    Boston, Ma
    I checked the fronts, not the backs, I didn’t want to break those clips but I will try that too. I just didn’t know if anyone else experienced it. If I move the seat in different positions it seems to go away but once someone gets in the truck and puts the seat in a comfortable position I notice it when they get out
  8. Oct 27, 2020 at 9:48 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    Heated/cooled seats? Might be a loose fan?
  9. Oct 27, 2020 at 9:49 AM
    Alex261
    Alex
    Boston, Ma
    They are heated and cooled and I will try to check that too
  10. Nov 10, 2020 at 6:48 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Warranty!
  11. Nov 10, 2020 at 7:24 PM
    biebs96
    PA
    It is the sound of the seat back and the seat bottom rubbing on each other.
    try adjusting the seat back a smidge back to add some space.
    this happened on my old limited and fixed the issue.
  12. Nov 10, 2020 at 8:25 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Make sure you don’t have a little piece of plastic or something rattling around inside the door grab thingamajig.
