Leaking trans and engine oil pan 02 4.7
Discussion in '1st Gen Tundras (2000-2006)' started by Averyklinnnn, Oct 25, 2023.
  1. Oct 25, 2023 at 9:17 PM
    Averyklinnnn
    Averyklinnnn [OP] New Member
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    My 2002 V8 4wd tundra with 680,000 miles is leaking from engine oil pan and where the transmission meets engine, real main seal? All original probably be easier to fix by pulling engine and trans together? Point me to some good threads, manuals, videos or share some knowledge. Thanks
  2. Oct 25, 2023 at 9:33 PM
    Mine is mildly weeping in the same area. Coming out of the bell housing. Until it gets worse I’ll just monitor it. When it comes time to fix, dropping the trans is likely the easiest route. I’ll have to research further. The FSM is available here and I have a Chilton’s manual I use as well.
  3. Oct 25, 2023 at 10:48 PM
    02TundraIdaho
    02TundraIdaho New Member
    LG
    02 Tundra / 11 ES350
    no Mods... has new headlights and some dings on the side... just purchased a dent puller and Bilstein 5100's for it..... absolutely love it in the 2 weeks I've owned it...
    680,000... nice!! How's the motor running? tranny? how long have you had it? everything original?
    You might check YouTube guy Car Care Nut.... He's strickly Toyota/Lexus master tech and does a ton of videos and if he covers this subject, chances are you won't need reference anything else!!! He goes through tricks and addresses hang ups... no nonsense good info from that dude!
  4. Oct 26, 2023 at 4:36 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I saw my pan had a slight leak as well. From what I saw, with 4wd you have to remove the front diff to get the pan off. I don't remember what else. Rear main wouldn't be bad just pulling the trans. It may not be a bad idea to pull it. You could also do your exhaust manifolds if they're ticking since the motor is out and they're a bitch to get to.
    BroHon likes this.
  5. Oct 26, 2023 at 7:06 AM
    When was the last time you did your valve covers? When mine were leaking at a whopping 72,000 miles, it coated the oil pan, mostly on the driver's side front of the pan. Valve cover gaskets seem to be notorious leakers on the 2UZ-FE if I'm going by collective input here.
    Re: Rear leak ..... Check the half-moon plugs that sit in this notch, or shine up from the rear to see if you see oil leaking from there? They should've been pulled/cleaned/re-sealed at every valve cover gasket change, along with the tube plug seals. I'd expect your truck to be on its 2nd or 3rd gasket change by now. Giving us some pics around the bay (from the top of the engin) in good daylight may help us help you find the leak.
    Weagle likes this.
  6. Oct 26, 2023 at 8:50 AM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    Post some picture
  7. Oct 26, 2023 at 8:53 AM
    TheKleen
    TheKleen New Member
    Kyle
    Gulf Coast
    2002 SR5 AC 4.7L 2WD LSD
  8. Oct 26, 2023 at 10:07 AM
    I wouldn't think of it like that ... It's a long-term solution you can run for the life of the oil, something more along the lines of regular-maintenance. Think of it like any other additive, it's essentially what big-name oil companies use as part of their additive package in their "high mileage" oils. Which is also similar to how big-name companies install additive packages into their gear oil for extra slip, heat protection, etc. AT-205 isn't, like, a stop-leak band-aid like Barr's Stop Leak or similar. The goal of AT-205 isn't to "get you by long enough to reach a mechanic", it's a seal rejuvenator. When you dump that bottle in, you're effectively turning your existing oil into higher-potency "high mileage" oil.
    BroHon likes this.
  9. Oct 26, 2023 at 10:37 AM
    TheKleen
    TheKleen New Member
    Kyle
    Gulf Coast
    thank you for this insight. I run high mileage oil already, do you think it would be a benefit for me to put in a bottle as a preventative measure on my next oil change? No leaks since doing my valve covers earlier this year. 238k
  10. Oct 26, 2023 at 10:56 AM
    It's not going to hurt anything, I run high mileage oil also. It squashed my cam seal leak and reduced my valve cover leak. But the source of my valve cover leak was a piss-poor job someone else had done prior with FIPG sealant in the corners nearest the timing cover. So I had to do the valve covers anyway, but I haven't seen a single drop of oil below the front driver's side cam tower, and there definitely was one there before.
    I'm running a bottle in my engine every 2nd or 3rd oil change for the full life of the oil. And I run a can of Seafoam high mileage in the crankcase about 500miles from each OC to help loosen up any stubborn carbon. What you do is up to you, and this may not work for you personally. It's what I've done with most of my cars.
    Whatever you do, just don't be that guy who uses a vacuum hose to suck Seafoam or other solvents up into your engine. They specifically warn you not to.
  11. Oct 26, 2023 at 1:16 PM
    Averyklinnnn
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    Definitely not valve covers I need to replace oil pan
  12. Oct 26, 2023 at 2:35 PM
    I don't deny it definitely needs to be re-gasketed. But this oil staining is up awfully high to just be the pan.
    dbittle likes this.
  13. Oct 26, 2023 at 2:45 PM
    Averyklinnnn
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    Manuals or videos on pulling engine and trans together??
  14. Oct 26, 2023 at 2:57 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    This is gonna be perceived wrong, but what is the upside to fixing this. How many other issues are gonna come up by pulling the motor? With the current mileage, is the expense of fixing it worth the trouble?
    rock climber likes this.
  15. Oct 26, 2023 at 3:08 PM
    Averyklinnnn
    Avery
    Colradddo
    2002 tundra sr5
    Stockk
    I've also got another motor and trans with 180,000 that I pulled out of a wrecked parts truck I kinda just wanna learn how to pull motor and trans it'd be cool to keep the original engine and trans going til it blows
    Tileguy likes this.
  16. Oct 26, 2023 at 3:46 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Makes sense. Im just imagining how many bolts/studs, wiring, and plastic clips are gonna break during the process
