Leak where rear diff meets drive shaft
Discussion in '1st Gen Tundras (2000-2006)' started by 805Tundra, Sep 1, 2022.
  1. Sep 1, 2022 at 4:37 PM
    805Tundra
    805Tundra [OP] New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    Toytec Aluma 2.0, Camburg UCA, 5160s and more.
    I noticed this on that back of the fuel tank. Smelled like gear oil and then saw this. It’s not dripping out but seems that it’s throwing some oil while the drive shaft rotates. Should I be worried? If so what fix am I looking at? Tried searching but having a hard time finding anything. Thanks!
    E2420B51-5055-4FAB-96C6-564222542270.jpg E9CF0796-A2F2-42F3-B3A8-A9870B11C5C4.jpg E9296D2A-A9ED-4435-A140-5CA0BCBE847B.jpg 208B020E-80A4-4163-804F-41DD6D6C43DA.jpg
  2. Sep 1, 2022 at 4:50 PM
    Aerindel
    Aerindel New Member
    Montana
    Just a pinion seal leak. Not hard to fix.
    You can drive like that forever as long as you keep topping up your gear oil. If you run dry, its a new rear end though.
    Grease your U-joints while your at it. They look a little dry.
    FirstGenVol and 805Tundra[OP] like this.
  3. Sep 1, 2022 at 4:54 PM
    805Tundra
    Ben
    Central Coast
    Awesome, I appreciate the info!
  4. Sep 1, 2022 at 5:49 PM
    Aerindel
    Aerindel New Member
    Montana
    Two other things to check now that I think about it more.
    The breath cap on top of the diff is notorious for getting plugged, this can cause your diff to get over pressurized and leak. Take that off and clean it out.
    Also, in the picture it looks like there is oil coming out from the U-joint itself, usually a leaking pinion will cause a leak closer to the diff, right under the seal flange.
    Its possible your pinion flange nut has come loose and its leaking internally around the threads, but that would be a strange failure.
    In either cause, you do the same thing as you would for fixing a pinion seal but its something to check.
  5. Sep 1, 2022 at 9:14 PM
    805Tundra
    Ben
    Central Coast
    i used the original diff breather for when I relocated it. I will check and make sure it is still functioning properly.
    I will also check pinion flange but as well as the pinion seal. Luckily, it sounds like it isn’t something to urgent as long as oil levels are good. Also, seems like a simple fox when the time comes.
    thanks my guy!
  6. Sep 2, 2022 at 7:21 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Shouldn't it be dripping from the actual flange?
    Also, if a flange leak shouldn't there be a splatter line across the bottom of the bed as the flange spins faster? Shouldn't it be flung further and further out?
    I've never had this leak so it could be a pinion seal. Just seems really weird. Is the side of the flange facing the pinion wet? Or is it only we between the mating surfaces?
    NickB_01TRD likes this.
  7. Sep 3, 2022 at 2:30 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    This is just what my fuel tank looked like when it started leaking due to rust under the straps. I opine that the pinion seal would be leaking from the other side of the flange, throwing lube in a much bigger arc, and the unmistakable fragrance of gear lube would be pervasive.
  8. Sep 3, 2022 at 1:35 PM
    Aerindel
    Aerindel New Member
    Montana
    OP says he smelled gear oil. I agree though, the placement of the drip looks a little odd, but if its gear oil there really isn't anywhere else it could come from.
    805Tundra[OP] and des2mtn like this.
  9. Sep 9, 2022 at 2:17 PM
    805Tundra
    Ben
    Central Coast
    I had originally thought my fuel tank was leaking but it didn’t smell like gas, instead it smelt like gear oil. After wiping the fuel tank clean you can see oil bending flung on it. This is clearly the culprit:
  10. Sep 9, 2022 at 3:45 PM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    :rofl:Saw your handle and went to the fridge to get me an ice cold 805
    The only thing holding the oil from leaking out is the pinion seal. As others have stated a pinion seal usually leaks out of the 3rd member. My theory is that the pinion seal is leaking at the inner portion of the seal where the pinion goes through, and travels along the pinion to reach the flange, rather than the outer section where the seal mates to the 3rd member. Either way... replace the seal and drink a beer :cheers:
    805Tundra[QUOTED][OP] and w666 like this.
  11. Sep 9, 2022 at 5:03 PM
    w666
    Maryland
    Indeed. So pinion seal it is. Easy fix
    805Tundra[QUOTED][OP] likes this.
  12. Sep 9, 2022 at 5:26 PM
    805Tundra
    Ben
    Central Coast
    Haha :yes:@Cruzer glad I could inspire you!
    Ya everything I have seen is it leaks out of the 3rd member but your theory makes complete sense. Might drink a few beers :thumbsup:
    Cruzer[QUOTED] likes this.
  13. Sep 9, 2022 at 8:32 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    You'll need a 30mm socket and something to unstake that staked nut. I used a chisel type bit that I thinned down to get in there. You should get a new nut for that as well.
    Disclaimer I did the pinion seal on my 95 Tacoma and this is how I did it. I believe the tundras are the same.
    tvpierce likes this.
  14. May 10, 2025 at 1:30 PM
    BalboaG97
    BalboaG97 New Member
    I have the same issue. I replaced the pinion seal but I still have a leak from the same area
  15. May 10, 2025 at 2:07 PM
    Any pics, to help us help you?
