Leaf spring bushings help
Discussion in 'Suspension' started by Spolar, Mar 23, 2017.
  1. Mar 23, 2017 at 8:04 PM
    Spolar
    Spolar [OP] Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Put on my Toytec shackles today which I ordered with the poly bushings. The shackles went on "easy" enough, took me over an hour, but easy enough for someone who's not mechanically inclined. However I couldn't get the factory bushings out to save my life. I worked on one for a little while then gave up, and just installed the shackles with the factory bushings.
    I guess I just assumed they would pop right out I didn't realize they were pressed in. So how the heck do you get those things out if you don't have a ball joint press or something? I suppose it's fine to leave the factory bushings on for a while and try and swap them out down the road...
    SoCal619 likes this.
  2. Mar 23, 2017 at 8:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Mar 23, 2017 at 8:44 PM
    Spolar
    Zac
    Seal Beach CA
    2016 sr5
  4. Mar 23, 2017 at 9:12 PM
    olsin6
    olsin6 New Member Vendor
    Joey
    Mesa, AZ
    2010 White DCSB Tundra
    35" Toyo MT w/ 17" Method Standards Body Mount Chop SDHQ Sliders
    We typically burn ours out. Easiest and fastest way.
  5. Mar 23, 2017 at 9:42 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    They charge you then give money back when you return.
    dcsleeper408 likes this.
  6. Mar 24, 2017 at 7:01 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    As @olsin6 said, we usually burn them out.... Easiest and quickest way to get them out...
    -David
    Hotwire and (deleted member) like this.
  7. Mar 24, 2017 at 7:13 AM
    PMG
    PMG New Member
    What's the consequence of using the old bushings (1-2 y/o) ?
    PMG
  8. Mar 24, 2017 at 7:16 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    OEM bushings have teeth that will bind on the the shackles causing damage and premature and unnecessary wear.. Upgraded poly bushings are flat where they touch the shackle-no bind.
    831Tun, PMG and joonbug like this.
  9. Mar 24, 2017 at 8:05 AM
    Newm
    Newm New Member
    KC
    Probably a dumb question...but here goes. When you say burn them out are you just using a torch and completely melting away the rubber bushing or heating up the spring eyelet a little to make it easier to beat/press the bushing out?
  10. Mar 24, 2017 at 8:22 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    I have a ball joint press, it doesn't fit. I didn't want to make a big Smokey burning rubber mess, so I made one for less than $10. I found this on another forum, it works great. You will one 1.5" galvanized or black iron tee and one plug. One ft. Of 1/2 inch all thread, three nuts and 3 or 4 fender washers( 1/2 inch hole, just small enough outside diameter to fit inside the eye of the spring. Double nut one end of the all thread, stack enough washers to keep them from bending. Drill a 1/2 inch hole in the pipe plug. Insert the all thread through the bushing and the tee. Tighten the nut while holding the tee in line with the spring eye and keep on cranking. I can snap a couple pics if you want. It's out in my shed.
    Newm likes this.
  11. Mar 25, 2017 at 5:48 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Newm, 15whtrd and Spolar[OP] like this.
  12. Mar 25, 2017 at 5:52 PM
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    That's the old bushing hanging out. You'll be sliding the bushing out of the spring into the tee. A piece of pipe the right diameter and length would probably work to.
    Newm likes this.
  13. Jul 1, 2018 at 2:00 PM
    Dilsky
    Dilsky Toyota Brand *****
    Shawn
    Edmonton, Alberta
    2014 Platinum Tundra Crewmax Black
    King Front Coil-overs Coachbuilder shims Toytec Rear shackles - Stock Rear Baja Designs Sport Fog Lights Rough Country 30" Lightbar 18" Method Roost Wheels (Bronze) 285/70/R18 Nitto Exo Grapplers Diamondback HD Cover
    Watched YouTube videos and made a device and tried borrowing a contraption from canadian tire, no go. Super pissed-off. Ended up melting them and light a small fire under my truck to get the sleeves out now I an stuck trying to get the new ones in. Should have just ordered a new leaf pack!
  14. Jul 1, 2018 at 2:04 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    If you melted the rubber out you still need to remove the outer sleeve. You can use a chisel or punch and just smack it out.
    ColoradoTJ likes this.
  15. Jul 1, 2018 at 2:14 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I usually do research before I try and tackle situations like this.
  16. Jul 1, 2018 at 2:17 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    Thanks @dcsleeper408 that is just what my brother in law were discussing.
  17. Jul 1, 2018 at 3:04 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
  18. Jul 1, 2018 at 3:17 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    If you have a sawzaw cut it and it will be easier to get out.
  19. Jul 1, 2018 at 4:21 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Now you tell me! Sh**, another unscheduled pit stop in the near future.
    dcsleeper408[QUOTED] likes this.
  20. Jul 1, 2018 at 4:30 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    Thanks for the help, got it all wrapped up, mostly just wasted a bunch of time getting the rubber out of the one sleeve when really I could have just cut it out. I did do research before but in everyone else came the bushing just slid out nicely. I suppose 150,000 kms will seize then up pretty good though.
    Black Wolf likes this.
  21. Jul 1, 2018 at 4:34 PM
    Dilsky
    Shawn
    Edmonton, Alberta
    Thanks! I had this tool and it would have worked if I had a couple more bolts. Mine was a 3/8 inch shaft and fit perfectly into the bolts so they just threaded through. But it should have worked haha.
  22. Jul 1, 2018 at 4:52 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Mo mods mo problemz
