leaf spring break
Discussion in 'Suspension' started by Rosie, Jan 16, 2018.
  1. Jan 16, 2018 at 7:00 AM
    Rosie
    Rosie [OP] New Member
    Rosie
    my drivers side leaf spring snapped in half today. Big air bubble in the metal where it snapped. Replace with OEM or aftermarket?
    No relief from toyota on this...SHITSTAINS
    Toytec Lifts likes this.
  2. Jan 16, 2018 at 7:11 AM
  3. Jan 16, 2018 at 7:19 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Hello @Rosie welcome to the forum!! Lets see the Tundra!
    :worthless:
    We have a complete OME Dakar pack replacement for the rear end for the Tundras, yes granted it will end up lifting the Tundra about 2'' in the back ( which we could also address the front end to help level back out if you want). The Dakar packs are an awesome leaf pack with a full 2 stage design, the primary stage will help support the Tundra along with giving you the lift, the secondary stage of the pack will then "kick in" once a extra load is added, that in turn will help support the weight, give great ride quality, and still maintain the proper lift.
    Here is a link to the leaf packs (note you need extended u-bolts with these)
    https://toyteclifts.3dcartstores.com/CS055R-OME-Rear-Dakar-leaf-springs-2007-Tundra-SET_p_1002.html
    Let me know if you have any questions or concerns,
    Thanks
    David
    T-Rex266 and Eclipsed & Floating like this.
  4. Jan 16, 2018 at 8:13 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Which leaf?
    Wheelers sells their own and Icons enhancement packs. Both provide lift though. They retain the main leaf and overload. If you dont tow a lot you can leave the overload off which will net you only about .75" of lift. I have been running overload free and have no issues towing roughly 4500/5k lbs.
    Just throwing it out there.
