LCA bolt
Discussion in 'General Tundra Discussion' started by Alexstundra, Aug 21, 2019.
  1. Aug 21, 2019 at 5:04 AM
    Alexstundra
    Alexstundra [OP] Not a new member
    Northeast PA
    2016 MGM DC Trd
    Does anyone know the measurements of the LCA long bolt that goes through the bottom of the shock. I took it out wrong and messed up the threads good and can’t tighten all the way so I put two washers on until I get new one. Hoping not to have to drive to Toyota
  2. Aug 21, 2019 at 5:32 AM
    I would get the OEM bolt. It is only $8.40. It is index #2 on the diagram. I searched it for the TRD Pro but they should all use the same bolt. https://www.sparksparts.com/auto-pa...ont-suspension-cat/struts-and-components-scat
  3. Aug 21, 2019 at 5:35 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Bah thank you I found that too just didn’t wanna drive 30 mins each way during the day I guess I’ll call em up
  4. Aug 21, 2019 at 5:43 AM
    If you have enough of the nut on the threads and its tight, you would probably be okay ordering it. Sparks ships pretty quick.
