LCA ball joint part number help!
Discussion in 'Suspension' started by SprinterAE86, May 31, 2021.
  1. May 31, 2021 at 2:42 AM
    SprinterAE86
    SprinterAE86 [OP] New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I have been hearing a crackling noise in my front suspension and can only be replicated while driving on rough terrain. I started noticing it after my first winter with this rig.
    I am going to be replacing all the wheel bearings, might as well redo the whole suspension and install an adjustable UCA and replace the LCA ball joint. I can't seem to find the Part # for the LCA ball joint in the parts catalog. I'm also going to go ahead and drain and fill my front and rear diff fluid and Transfer case while I'm down there. I need to start shopping for Amsoil dealer in the Maritime, PEI to be precise.
    Wanted:
    LCA ball Joint part number or good replacement part other than OEM.
    TIA
  2. May 31, 2021 at 2:58 AM
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    LBJ not typically sold as a separate item for our model. Usually have to buy the whole LCA. OEM around 500 for a set, but you can find others around 300, not sure of the quality. If you have access to a large press, or have a shop, you can take the LCA and have a LBJ pressed in. Here's a link to one made in Japan. There are a few single LBJ out there, but limited options. To answer your question, I'm not sure there is an actual part number for it, it comes with the LCA.
    https://smile.amazon.com/dp/B00DZMNGBU/ref=cm_sw_r_cp_apa_glt_fabc_DQWGKHDBCNAJP97VW177
