LCA adjustment cams need anti seize - do this now
Discussion in 'General Tundra Discussion' started by csuviper, Apr 15, 2016.
  1. Apr 15, 2016 at 8:03 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Just found out my 2012 RockWarrior with 50k miles has seized lower control arm adjustment cams. These need anti seize on them as soon as possible to prevent them from seizing. Common issue with Tundra and other vehicles. Just wasn't quick enough getting it done.
    Add anti-seize to your LCA adjustment cams now!!!!!
    Black Wolf and Wynnded like this.
  2. Apr 15, 2016 at 8:08 AM
    csuviper
    Broomfield, CO
    This will cost upwards of $1500 in parts and labor if new LCAs are needed.
  3. Apr 15, 2016 at 8:12 AM
  4. Apr 15, 2016 at 9:58 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Suppose I'd better get on that, I remember the experience with my Tacoma. I had to use a die grinder to get them suckers out.
  5. Apr 15, 2016 at 11:00 AM
    csuviper
    Broomfield, CO
    Ouch. Sold my Tacoma with one seized. Alignment came in within spec without having to remove it though
  6. Apr 15, 2016 at 11:11 AM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    No because you have to align it after you take those out
    T-Rex266[QUOTED] likes this.
  7. Apr 15, 2016 at 12:57 PM
    Mine are probably froze by now.
    High 5 myself
  8. Apr 15, 2016 at 4:20 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    We can high 5 our selfs together.
    I'm sure mine are fucked also
    Black Wolf likes this.
  9. Apr 15, 2016 at 5:45 PM
    Dang it. I guess I need to take a look this weekend. Should be fun with a ft or 2 of snow. PB Blaster??
  10. Apr 15, 2016 at 6:20 PM
    Ericsopa
    Ericsopa Old man and the sea
    I'm relatively new to the truck, so pardon my ignorance .... assume this means that, at a minimum, a bolt/nut has to be loosened, and the end result is alignment will be necessary afterward?
  11. Apr 17, 2016 at 5:23 PM
    Medic
    Medic New Member
    Ontario, Canada
    2014 Limited Crew Max
    Thanks for the info. Will look into tomorrow.
  12. Apr 17, 2016 at 6:12 PM
    csuviper
    Broomfield, CO
    Yes after you pull these out and add anti-seize you will need to get an alignment.
  13. Apr 17, 2016 at 6:16 PM
    csuviper
    Broomfield, CO
    This would be nice:
  14. Apr 17, 2016 at 6:23 PM
    csuviper
    Broomfield, CO
    Should be ok with new Toyota ones and lots of anti-seize though.
  15. Apr 17, 2016 at 6:45 PM
    Ericsopa
    Thanks. Truck in Corpus Christi for it's first three years, salt air and all that.....so I'll be doing it real soon.
  16. Apr 19, 2016 at 2:23 PM
    McTundra12
    McTundra12 New Member
    '12 CrewMax TRD
    Notta
    Just formed over to have the alignment shop to replace the passenger side. The truck looks sweet after 5100 level, but this sours the taste a little.
