Launch shudder after lift?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ibanez6224, Sep 17, 2019.
  1. Sep 17, 2019 at 8:55 AM
    Ibanez6224
    Ibanez6224 [OP] New Member
    2019 TRD OR
    Anyone experience this? Just put a lift on my truck this past weekend, and experiencing it slightly. Will it settle over time?
  2. Sep 17, 2019 at 8:58 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    How big and what kind of lift?
    Pinay and 15whtrd like this.
  3. Sep 17, 2019 at 8:59 AM
    15whtrd
    15whtrd Mr. Blonde
    Pretty vague. Helps to know exactly what you lifted a.k.a. front and back, size, parts used etc. If you lifted the rear you may need to look into a carrier bearing drop if you’re having shudder or vibrations coming from the rear.
    jeremyd, Pinay and dcsleeper408 like this.
  4. Sep 17, 2019 at 9:02 AM
    Ibanez6224
    2019 TRD OR
    Sorry about that. It's an ironman suspension 3/1 kit, well technically 2.5" kit. Front coilovers, rear shocks, and rear leaf spring pack. Here's the kit for reference. Talked to one of the guys at the shop I was working with and he said it might settle down, but wouldn't do anything about it for a 1,000 miles or so and shouldn't hurt anything. The shudder isn't super bad by any means, but I feel it.
    https://ironman4x4america.com/truck...=pricedesc&Make=Toyota&Model=Tundra&Year=2019
    15whtrd[QUOTED] likes this.
  5. Sep 17, 2019 at 9:09 AM
    Ibanez6224
    2019 TRD OR
    Posted further down in the comments.
  6. Sep 17, 2019 at 9:12 AM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    I lifted my rear 1.5” with shackles and noticed a small shudder from the rear around the 1-2 shift under low load (light acceleration, under 20mph). I added a 1/2” spacer to the carrier bearing and it got rid of it. Your mileage may vary. ;)
    15whtrd likes this.
  7. Sep 17, 2019 at 9:13 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Sounds like carrier bearing is most likely culprit. The slightest angle change at the pinion can mess with things
    jeremyd, 15whtrd and Pinay like this.
