Last minute gut check before I spend lots of money
Discussion in 'Wheels & Tires' started by bigblue14, Nov 21, 2018.
  1. Nov 21, 2018 at 3:17 AM
    bigblue14
    bigblue14 [OP] New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    I'm planning to buy the Toytec Boss kit with the rear add a leaf and SPC UCA. My tire plan is 285/65r20 KO2s or 295/60r20 Falken Wildpeaks ATs. The plan is to keep the stock platinum wheels but use Bora spacers. Hopefully I only need to massage some plastic.
    Any concerns about 295s on an 8" rim? Any specific love for one tire over the other? I'm intrigued by the Falkens as they are less expensive and still get good review everywhere I look BUT are more of an unknown. Rain and snow traction are my main focus.
    I appreciate any advice!
  2. Nov 21, 2018 at 3:28 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Based off of my research, either tire size should work. I literally put new tires and wheels yesterday. After removing the front mudflaps, i only get rub at certain angles on the driver side at full lock. Im on a 35x12.5 on a 9 inch wheel though. With that being said i think you will be ok. For the record i went with KO2s. My go to tire from here on out
  3. Nov 21, 2018 at 5:31 AM
    Pretty sure you should be on a 9” wheel
    Marty McFly, Rica25 and Black Wolf like this.
  4. Nov 21, 2018 at 5:52 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Agreed. Although, Falken does say that approved width rim for both of those tire sizes is 8"-10". But, I still would bump up the width to a 9" if it were me.
    Rica25 likes this.
  5. Nov 21, 2018 at 6:09 AM
    bigblue14
    Craig
    Right the approved rim width is 8-10 but I would be pushing the width by ~.5" per the mfg specs. If I go with the Falkens they offer both sizes.
    Rica25 likes this.
  6. Nov 21, 2018 at 9:11 PM
    mac10tuna
    mac10tuna New Member
    Marc
    19 cement limited CM
    Not sure how Falken is still an unknown to so many people.
    The AT3W is an a excellent tire.
    It should definitely be one that you consider.
    bigblue14[OP] likes this.
  7. Nov 22, 2018 at 4:34 AM
    bigblue14
    Craig
    So all this talk of sidewall flex made me do some maths. This is a purely a relative check for anyone who is interested. For sure there are other factors at play eith moving to a larger tire.
    The middle is my current scenario of 285/55r20 on the factory 8" rim. I have a sidewall flex angle of 14.62°. 285/65 reduces it slightly to 12.45°. 295/60 is basically the same as my current tire at 14.5°.
