Largest tire size on stock 2015?
Discussion in 'Wheels & Tires' started by hvfd25, Jan 9, 2017.
  1. Jan 9, 2017 at 2:37 PM
    hvfd25
    hvfd25 [OP] HNTFSH
    Maine
    2015 Tundra Crew max SR5 TRD Package
    Hey new to the group... Switched from years of GMC. 2015 Crew max...I am buying new tires ASAP. Installing a 3/1 level lift this week and plan on keeping the stock TRD 18s. What is the largest size tire I can run with out any significant mods?
  2. Jan 9, 2017 at 2:42 PM
    Bob
    Bob Member Staff Member
    Bob
    07 Tacoma PreRunner Black
    Welcome to the site!
    Subbed so we can make a sticky "largest tire size" thread.
  3. Jan 9, 2017 at 2:42 PM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    You should be ok with 295/70/18 seems to be a popular choice for 18s. I've also seen 305/65/18 on @BlueBottle truck. @Sean266 is running 35s on his with 3.5" lift.
    T-Rex266, hvfd25[OP] and Bob like this.
  4. Jan 9, 2017 at 2:59 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Im running 305-70-18 (35's) with a frame cab chop ( not a major mod ) on 3 inch coilovers.
  5. Jan 9, 2017 at 4:16 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    zcarpenter92 and hvfd25[OP] like this.
  6. Jan 9, 2017 at 4:36 PM
    hvfd25
    hvfd25 [OP] HNTFSH
    Maine
    Thank you. I will do that.
  7. Jan 9, 2017 at 4:40 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    With the stock wheels you're going to need wheel spacers or you're going to rub your uca's.
  8. Jan 9, 2017 at 4:50 PM
  9. Jan 9, 2017 at 4:55 PM
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    Forget it get some new rims while your at it and stuff 35's on it. Badass look. Just got mine last week.
  10. Jan 9, 2017 at 4:58 PM
    hvfd25
    hvfd25 [OP] HNTFSH
    Maine
    What would I need for off set and back spacing to run a 34 or 35? Can you go down to a 17" wheel or stay 18" or larger
  11. Jan 9, 2017 at 5:46 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Welcome. Some 17" work and some don't because of the calipers. Stock rock warrior rims are 17". Stock trd rims are et 60. I used 1.25" spacers on stock rims to get something like et 28.25. I'm running 295 70 18 Cooper stt pro and had to remove the mud flaps and should do the CMC. My truck is lifted between 3 - 3.5". The stock skid plate will need some minor trimming as well. The trucks differ slightly and these are just my experiences.
    hvfd25[QUOTED][OP] likes this.
  12. Jan 9, 2017 at 6:08 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    offset of +18 to 25 seem's to be the sweet spot for fitting larger tires on 3" lift on our trucks. With my 305/65/18's, I had to remove both forward and rearward mud flaps on the front wheel and trim and push forward the wheel liner. with 35" tires, there is a great chance you will rub on the frame.
    This is how close mine is on my current setup
    C8C34718-ED08-4AD0-98E6-D57D199DEC32_zps_17d273d930ba8e00df1f85ba5d7c7ef398ef2a49.jpg
    831Tun and joonbug like this.
  13. Jan 9, 2017 at 6:17 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    35, you can always fit a 35. Just takes a bit of work depending on the lift.
  14. Jan 9, 2017 at 6:55 PM
    louscrw
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    To the best of my knowledge, the only 17" wheels that will work on our trucks are the Rock Warrior and Method wheels
    831Tun likes this.
  15. Jan 9, 2017 at 7:13 PM
    209TRDPRO
    2016 Tundra TRD PRO
    Just lights for now
    Mine is tight like that too. I cut a hole on both front plastic due to rubbing but on 35's
  16. Jan 16, 2017 at 8:19 AM
    hvfd25
    hvfd25 [OP] HNTFSH
    Maine
    Well it's all done and my nerves can rest easy now haha. Supreme Suspensions 3/1, 295/70/18 Nitto G2's on stock TRD wheels. Only rubbing was on the skid plate and the sway bar at full lock. After the alignment it only rubbed the skid plate. I cut the affected area off and seems to be fine with no issues now. Will have to work the suspension to see if there is rubbing with flexing. It looks like there won't be.
    joonbug likes this.
  17. Jan 16, 2017 at 8:21 AM
    hvfd25
    hvfd25 [OP] HNTFSH
    Maine
  18. Jan 16, 2017 at 8:24 AM
    hvfd25
    hvfd25 [OP] HNTFSH
    Maine
    Looking into Exhaust for the next addition ... any recommendations on a dual cat back system that won't break the bank?
