Largest spare that will fit?
Discussion in 'Wheels & Tires' started by Peteway, Apr 12, 2020.
  1. Apr 12, 2020 at 8:55 AM
    Peteway
    Peteway [OP] New Member
    2019 5.7 CrewMax 4x4
    Does anyone know what is the largest spare tire that will fit under the truck?
    I just got my icon suspension system installed (3 inch in the front and 1.5 rear) and I'm looking at getting some 295/70r18 (which should be about 34.3" tall) ... I'm assuming that won't fit, but what would fit?
    obligatory pics included.....
    Flyinryank, TacomaLC and Mountun Goat like this.
  2. Apr 12, 2020 at 9:21 AM
    Shaggie13
    Shaggie13 New Member
    Mitch
    Central CA
    2017 TRD Pro Tundra Superwhite
    Fifteen52 wheels, rolling on tires.
    I fit a 315/70/17 tire. I did some banging on the guiding tabs, and needed my son to crank it up while I guided it in place, but it fit.
    equin likes this.
  3. Apr 12, 2020 at 9:22 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I’ve heard a 35” aired down will stuff in with some hammer time
  4. Apr 12, 2020 at 9:43 AM
    Pnoy_toy
    Pnoy_toy New Member
    35’s will fit if you remove the guide tabs
    Flyinryank and Mountun Goat like this.
  5. Apr 12, 2020 at 10:15 AM
    Peteway
    Awesome, thanks for all the responses.
  6. Apr 12, 2020 at 10:41 AM
    TheBeast The Beach
    35"s will fit. I currently have a full size 295/70/18. I cut the tabs and still space left to squeeze a 35.
    Flyinryank and 41bigdawg like this.
  7. Apr 27, 2020 at 5:46 PM
    ostm282
    ostm282 New Member
    Stock 2018 Tundra Limited Silver
    2" leveling kit installed up front
    I just bought a used Nitto Terra Grappler G2 to use as a spare in a 295/70/18 to match the 4 new Cooper AT3 XLT tires I just put on my truck in that same size. After some thought, I decided to use the Sawzall to cut the spare tire tabs off completely. I hit them with a little paint and it turned out perfectly. The larger tire needs to be guided up into position but there's plenty of room. No rubbing on the shackles and not even close to the exhaust. IMG_20200426_110726.jpg IMG_20200426_110755.jpg
    AggiePhil, equin and Peteway[OP] like this.
  8. Jul 30, 2022 at 3:56 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I'm thinking of removing the guide tabs tomorrow in preparation to try and fit a larger tire. However, I took some measurements and only getting 32 inches between the coachbuilder shackles and 32 inches from the hitch to the DirtyDeeds resonator.
    Anybody have any ideas what a lower PSI 285/75/18 tire would be height wise? I was looking at the Yokohama Geolander A/T which is a 34.7" tire.
  9. Aug 30, 2022 at 8:25 AM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    What tire specifically? I know the Toyo M/T is almost 36" (35.7")
  10. Apr 15, 2024 at 8:31 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
  11. Apr 15, 2024 at 9:04 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    purplenova[QUOTED] likes this.
