Larger tire a
Discussion in '3rd Gen Tundras (2022+)' started by 19604X4, Mar 6, 2023.
  1. Mar 6, 2023 at 8:03 AM
    19604X4
    19604X4 [OP] New Member
    2024 Toyota Tundra TRD Pro
    Wanting to keep the stock suspension that came with my TRD off road suspension with Bilstein shocks but what would be the largest tire that I could increase to get a little more height.
    Truck came stock with the Falken Wildpeak 265/60R20 which was part of the (TRD Off-Road Package).
    Kind regards to all
  2. Mar 6, 2023 at 9:11 AM
    19604X4
    Much appreciative for the quick reply sir!
  3. Mar 6, 2023 at 9:22 AM
    BryMan83
    BryMan83 Slappin da bass mon
    Rio Rancho, NM
    2022 Tundra SR5 TRD OR 4x4 CrewMax
    Do it! I've seen quite a few on here with 35's on stock suspension. Personally, I think it looks too stuffed but apparently, they fit and like ryanwgregg stated, trimming should be minor. I'm running a slightly larger tire than the stock Michelins. Mine are a 33" and I'll likely go up just a bit bigger next set. 295/65R20 would likely be a good option for yours. All the best.
  4. Mar 6, 2023 at 9:42 AM
    Tom
    Tom New Member
    33” in MT tire will look tough without 35” trimming. Just my thoughts.
  5. Mar 6, 2023 at 11:00 AM
    Tb2
    Tb2 New Member
    James
    My issue is when you go 295 you get load range E which is a rougher riding tire and much heavier.
    I am looking for 275-285 in load range D. anyone know of a all terrain in 20 inch
  6. Mar 6, 2023 at 11:03 AM
    Tom
    Tom New Member
  7. Mar 6, 2023 at 12:54 PM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    35x11.5R20 fits on factory TRD 20" rims with mudflaps, no trimming, no leveling kit needed and no rubbing... much improves the looks as well... IMO..
  8. Mar 6, 2023 at 1:27 PM
    Tb2
    Tb2 New Member
    James
    what brand did you use
  9. Mar 6, 2023 at 1:58 PM
    bcj001
    bcj001 New Member
    Brad
    Oregon
    22' Tundra Limited
    Nitto Recon Grapplers which are a 10ply... didn't really notice to much of a "stiffer" ride, but took a little MPG hit... still get almost 19mpg on the flats doing 65... so no complaints... there are some other posts on here with some "non-10ply" options, specifically looking at tire weights... the 10ply didn't bother me less flats on the gravel roads! lol
  10. Mar 10, 2023 at 10:51 PM
    BryMan83
    Rio Rancho, NM
    Heavier, sure. Rougher, eh. I went from the Michelin LTX Trail, XL load, to an E rated Cooper Discoverer in 275/70R18 and I don't feel it diminished from the ride, traction however, is far better with the Coopers. My Tacoma, I went from XL to C to E (General Grabber) and it too felt fine. You're going to be hard pressed to find a 275 or 285 on a 20" wheel in D load.
