Large Cable Through Firewall???
Discussion in '2.5 Gen Tundras (2014-2021)' started by codename607, Mar 4, 2020.
  1. Mar 4, 2020 at 7:09 AM
    codename607
    codename607 [OP] New Member
    Chicago
    2024 Tundra
    Any idea how I can get a large cable from the cabin into the engine bay?
    I've searched a few different topics but I haven't found a solution yet.
    Here is what I'm trying to do:
    I have a Goal Zero Yeti 1400 mounted in the back seat area. I use it to power my fridge that is also mounted in the back seat area. The Yeti will power the fridge for about 4-5 days and then I need to charge the Yeti unit.
    In order to charge the Yeti unit I purchased a system called Yeti Link. This allows you to charge the unit off the truck battery.
    The problem that I'm running into is that the cable that connects to the battery is too large to run through the firewall.
    I will likely need to drill another hole or run the cable through another source, in order to reach the battery.
  2. Mar 4, 2020 at 7:32 AM
    codename607
    Chicago
    2024 Tundra
    It would charge but it's not as efficient as the Yeti Link. The Yeti Link will allow 300-600watts as oppose to other plug in solutions.
  3. Mar 4, 2020 at 7:34 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    that and you can't charge a big battery from a small battery
  4. Mar 4, 2020 at 7:58 AM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    There is a large rubber grommet under the center console. I ran my GMRS antenna line through it to run to my bed rack, its dead center on the front seat line. I just used a drill bit and drilled though it ran the wire and put some silicone around it. The rubber is wide enough you should be able to pass any large wire through. To access the grommet just pop off the kick panel on console, pop off the top where the gear shift is, remove the four bolts at the bottom of the storage area and the storage area will fall back and you can access the grommet.
    codename607[OP] and Sunnier like this.
  5. Mar 4, 2020 at 8:03 AM
    codename607
    Chicago
    2024 Tundra
    Perfect! Thanks for the details. This sounds like a solution for me.
  6. Mar 4, 2020 at 8:05 AM
    codename607
    Chicago
    2024 Tundra
    Yeah, the cables are pretty thick. About the size of normal battery cables inside the engine bay. I was going to use the grommet on the drive side to enter the engine bay but it's not big enough. I'll use the recommendation from Grendel.
  7. Mar 4, 2020 at 8:21 AM
    Stig
    Stig New Member
    You could also go under the frame then up through the floor grommet by the rear door. Easier to check that you've resealed it properly and of not there's at least no fumes coming from the engine bay.
  8. Mar 4, 2020 at 9:33 AM
    coTony
    Tony
    Montrose, CO
    ^^^^Beat me too it^^^^
    I would no way want to put a large cable through my firewall
  9. Mar 4, 2020 at 9:44 AM
    codename607
    Chicago
    2024 Tundra
    I'll have to check this rear floor grommet. Will it be under the seat area or back up against the cab?
  10. Mar 4, 2020 at 9:48 AM
    Grendel
    Grendel New Member
    I was never able to find the one on the floor under the rear door. I did find the one on the floor under the center storage. It was easy to access from both top and bottom. I probably didn't make it clear that it is not through the firewall but through the floor underneath the center storage.
    codename607[OP] likes this.
  11. Mar 4, 2020 at 9:50 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    There is also a large floor grommet under the passenger side front carpet, used it to run my power tailgate cable. Not sure about ones in the back seat area but easy way would be to go under the truck and find them.
  12. Mar 4, 2020 at 10:20 AM
    coTony
    Tony
    Montrose, CO
    I believe they are under all 4 seats, I have used the 2 under the rear seats. Not the easiest to get to but not bad, just be patient
  13. Mar 4, 2020 at 10:45 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    The grommet on the firewall should have a large nipple on the bottom of it. Just cut that nipple off and you should be able to run large wire through it. I ran the wire for my amp through the driver's side grommet.
  14. Mar 4, 2020 at 4:07 PM
    Grendel
    Grendel New Member
    @codename607 For what it’s worth. Here are pics of the grommet I went through 775D10BB-BF43-45E1-ADA1-AA71D617EB21.jpg17583A70-BF2D-44B7-AFD5-C458F86C280F.jpg
    cowboyjack and Ely010606 like this.
