Landscape lighting
Discussion in 'Off-Topic Discussion' started by Rolodetective, Oct 1, 2018.
  1. Oct 1, 2018 at 11:36 AM
    Rolodetective
    Rolodetective [OP] Member
    Vale of Paradise, Indiana
    2004 Black AC TRD
    Checking to see if you guys have recommendations for good landscape lighting?
    I'm looking for simple and traditional, low voltage landscape lighting for the front of the house. Really not interested in the junk at Menards or Homedepot but seems like the next option beyond those sources is $$$$.
    What do you guys use that you can give the good, bad and ugly about?
  2. Oct 1, 2018 at 12:02 PM
    acmesupply
    acmesupply New Member
    2018 SR5 CM Silver TRD
    I suggest the Malibu line with all metal bodies and glass lenses. Parts are available and sometimes interchangeable. Pay extra for the led lights. If you have lots of light positions do not use more than 75 percent of the total output. If you need more positions then buy a dual transformer and run two lines out so no dimming at the ends of the runs. The cheaper stuff at box stores will work, but fading, cracking plastic and poor connections will cause problems.
    I suggest using waterproof wire ties that have dielectric grease in them instead of the factory connectors. Use lowest gauge wire you can afford and always leave extra at the ends and bury to avoid lawn mover strikes etc. If I was to put in ground now I would put in 3/4" PVC pipe to run the lines but that is if you have open areas to lay it.
    All commercial systems cost more for 5 lights than a complete Malibu system .
    Rolodetective[OP] likes this.
  3. Oct 1, 2018 at 12:10 PM
    War Machine
    War Machine SSEM # 5 3MW
    Really depends on budget. Kichler makes really good stuff, but it’s a lot more than the stuff at Lowe’s Or Home Depot.
    I used Portfolio LED landscape lights from Lowe’s. It’s been there a couple of years with no issues, besides having the connectors go bad. I’ve only had to replace the ones that have been run over in the driveway.
    Like the previous poster said, the connectors that come with them are garbage. I replaced them with these:
    Kichler 15529BL Accessory Pro Connector, Brown, Pack of 10 https://www.amazon.com/dp/B004BN14TI/ref=cm_sw_r_cp_tai_jcNSBb051E15Y
    They are very good, and you’ll save some time and trouble by using something like that up front. Wirenuts with grease will work also, but I feel like these are more durable.
    Like you said, the stuff at the big box stores isn’t the best, but there is a huge gulf in pricing after that.
  4. Oct 1, 2018 at 12:49 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Been using the Portfolio LEDs from Lowes, not really that cheap $35ish each. But worth it over the halogen's; cheaper but more maint. and less longevity. Just finished replacing all my halogens as the go out. You can also use a many more LED's on a power supply due to less current draw each.
  5. Oct 3, 2018 at 3:19 PM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    I went with Volt.
    https://www.voltlighting.com/
    It is good quality stuff.
  6. Oct 4, 2018 at 3:16 AM
    Rolodetective
    2004 Black AC TRD
  7. Oct 4, 2018 at 3:20 AM
    CincyCrewMax
    CincyCrewMax New Member
    Cincinnati, OH
    2014 White CrewMax LTD.
    I'm putting in landscape lighting the next week or two. I went with Kichler. It's a little more pricier than the Home Depot/Lowes/Menards, but to me, it's worth it.
