Land Cruiser V35A Engine
Discussion in '3rd Gen Tundras (2022+)' started by Jowett, Jul 5, 2021.
  1. Jul 5, 2021 at 2:42 PM
    Jowett
    Jowett [OP] New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Hopefully the Tundra receives the dual airbox design.
  2. Jul 5, 2021 at 2:58 PM
    Kelvin
    Kelvin New Member
    Aw shit. Dual snorkels here we come.
  3. Jul 5, 2021 at 3:00 PM
    careyrob
    careyrob In the field
    Carey
    Massachusetts
    2008 Crewmax TRD 4x4 Silver
    LRO 3/1 leveling lift 35x12.50's on 20x9's Hellwig rear sway bar B&M 70264 SuperCooler Transmission Cooler Firestone airbags Daystar cradles Air Lift WirelessONE Compressor System
    Two airboxes -> two air filters & two snorkels.
    I'm not sure that I agree with that design decision. Would it have two throttle bodies and two mass air flow sensors?
    Unnecessary complexity.
  4. Jul 5, 2021 at 3:14 PM
    DanielDD
    DanielDD Too Old to Rock and Roll and Too Young to Die
    2001 TRD Tundra
    Sorta reminds me of the BMW V12 I used to own. It had 2 airboxes (and 2 MAF, and 2 throttle bodies...)
    Wallygator, equin and Jowett[OP] like this.
  5. Jul 5, 2021 at 3:19 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Looks like two MAFs in that photo next to the airboxes
  6. Jul 5, 2021 at 3:20 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Did it count as a single engine or a twin engine???
  7. Jul 5, 2021 at 3:26 PM
    Jowett
    North Adams, MA
    Many on the way.
    The 1UR-FSE 4.6 V8 in the old LS 460 uses dual airboxes, no problems.
    Yes, the V35A has two throttle bodies.
    Wallygator likes this.
  8. Jul 5, 2021 at 3:32 PM
    outlaw.taco
    outlaw.taco New Member
    Houston
    :rofl::rofl:
  9. Jul 5, 2021 at 3:34 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Guys will be able to run two different cold air intakes!
  10. Jul 5, 2021 at 3:46 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Will ya have to have two Pedal Commanders too????
    Joro43 likes this.
  11. Jul 5, 2021 at 4:16 PM
    careyrob
    Carey
    Massachusetts
    You can do an A/B test on the same vehicle at the same time. Use a different brand on each side.
  12. Jul 5, 2021 at 4:22 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    It will run like Maradona
    Saltyhero13 likes this.
  13. Jul 5, 2021 at 5:44 PM
    abomb60
    abomb60 Maker of things
    Massachusetts
    2018 Tundra 1794 MGM
    Only 2 throttle bodies? The V10 in my old BMW M5 had 10 throttle bodies ;)
  14. Jul 6, 2021 at 6:47 AM
    Tundra TTH
    Tundra TTH New Member
    What is under these two covers?
  15. Jul 6, 2021 at 6:57 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Look at the LS500 to get an idea. Driver side is brake fluid, not sure what the passenger side is?
  16. Jul 6, 2021 at 7:36 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    What is the blue looking container next to the upper radiator hose? Looks like power steering fluid, but I'd be absolutely stunned if they kept hydraulic power steering (for better or for worse).
  17. Jul 6, 2021 at 10:30 AM
    Tundra TTH
    Windshield wiper fluid
  18. Jul 6, 2021 at 11:21 AM
    BecauseRacecar
    Ohio
    But the windshield wiper fluid fill port is right in front of the driver's side air filter box.
    captainnemojr likes this.
  19. Jul 6, 2021 at 8:42 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    Looks like PS fluid
  20. Jul 7, 2021 at 6:03 AM
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    The engine cover says "Twin Turbo" and not iFORCE MAX. No blue on it either, so the hybrid speculation of the MAX seems realistic.
    The blue looking reservoir seems like PS fluid. I thought "modern" vehicles used electric PS?
    The wiper fluid is right behind the drivers headlight in front of the intake. You can see the cap. I say drivers even though it's probably a RH drive vehicle...
    snivilous likes this.
  21. Jul 7, 2021 at 6:25 AM
    sn_85
    sn_85 New Member
    Boise
    No it's not my friend. Its the PS fluid reservoir. Go look under your hood and locate the PS fluid reservoir and compare how it looks and how the lid looks. Most cars have their windshield washer fluid reservoir located down lower and the fill tube comes up to the top. The washer fluid tube typically has a flip cap and the PS fluid reservoir has that round grooved cap that looks like a cog. In this picture the windshield wash fluid fill tube is clearly in front of the driver side air box.
  22. Jul 7, 2021 at 6:26 AM
    Tundra TTH
    Doesn’t lane warning and return nudge back into lane require electronic steering or can they also do it with a traditional power steering pump? Agree that the windshield fluid is up front of the air box. That looks more like the correct cap for wiper fluid.
  23. Jul 7, 2021 at 6:34 AM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Wheres the battery?
  24. Jul 7, 2021 at 6:36 AM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    The 300 series will have hydraulic power steering. Any of the renderings from the series of videos Toyota has posted on youtube covering the 300s technical aspects clearly show a hydraulic rack. Personally, this makes me very happy as the vast majority of EPS systems feel like crap.
    You can see the hydraulic rack around the 11 second mark.
    https://www.youtube.com/watch?v=iUh5um1Z0Us
    Acedude and Wallygator like this.
  25. Jul 7, 2021 at 6:36 AM
    Wallygator
    Maybe in the back of the vehicle? Or under one of those covers?
  26. Jul 7, 2021 at 7:54 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Ford hides the battery under a cover like that now in the explorer. All this plastic under the hood looks stupid, hopefully it at leasts keeps components from getting chewed by rodents!
    Darkness, Terndrerrr and Wallygator like this.
  27. Jul 7, 2021 at 10:21 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Oh you poor devil. An E60 M5, did it eat the rod bearings while you had it or fail due to something else?
    I got to drive a few when I worked for a BMW dealer. That was an intoxicating sound from that V10, but I wouldn’t trust one of those cars to make it past warranty.
  28. Jul 7, 2021 at 10:27 AM
    Coal Dragger
    Kung Fu Dick
    My guess is it is coolant reservoir for the front radiator handling the air to liquid intercoolers.
    Edit: never mind someone found a diagram.
  29. Jul 7, 2021 at 10:39 AM
    Coal Dragger
    Kung Fu Dick
    The alternatives for a twin turbo V layout engine are:
    1.) Design a cylinder head that exhausts to the inside of the V and allows the turbos to sit in the V and use a unitized air inlet and air box. Then route all piping and intercooler etc to what will for sure be two intake manifolds and two throttle bodies.
    2.) On a conventional cylinder head with the turbos on the outside edges of the heads, design a bunch of convoluted plumbing to try to unite them on one air box while also ensuring even air flow to both so that both turbos work properly. Then adding on the necessary plumbing to the intercooler and intake manifold.
    If you look at it that way Toyota is choosing the most simple solution.
    careyrob[QUOTED] likes this.
  30. Jul 7, 2021 at 3:49 PM
    Tundra TTH
    So the two rectangular side grills under the headlights end up being very functional. Like the idea of the intercoolers having their own cooling system and that they don’t set on top of the engine like others do. Like it, each turbo has its own intake and intercooler. They just need to complete it and give each turbo its own separate exhaust out the back. Maybe that is why it has been reported by some of a tail pipe on the left and by other on the right, and in the end it will be a dual exhaust. Also, like the fact they have an auxiliary electric fan, apparently they found a need under certain conditions that they need to blow more heat off. Getting why they have a big porous grill.
