Kings Suspension & Tire Combo
Discussion in 'Wheels & Tires' started by ctdomain, Aug 9, 2019.
  1. Aug 9, 2019 at 2:11 PM
    ctdomain
    ctdomain [OP] Expeditioner
    Clint
    2019 Limited Quicksand Tundra
    Suspension: ADS Front C/O's w/adjusters, ADS Piggyback rears, Toytec Shackles, Icon Rebound 17in wheels +25 offset, 35x12.50xr17 Nitto Ridge Grapplers. Miscellaneous: Tech 12 volts remote start, Tyger side steps, Color matched pro grille & bulge, Black handles off of SR5 Tundra
    What is up guys, currently shopping for my new tire/wheel combo. I'm taking delivery of Kings extended OEM shocks front and back and Deaver U748's hopefully three weeks from now (fingers crossed no delays). I've been researching the hell out of this and I'm stumped.
    I would like to run a 35" Nitto Trail Grappler 11.50" wide tire on a 9"rim. My issue is I do not want that thing to rub and cause cutting. I feel I need to be around the +20mm offset range, but I lack the knowledge to understand appropriate backspacing to avoid rubbing.
    The new suspension will have TC UCA's and the Kings will be adding up to 3" of "lift" if needed.
    Please help a noob lol
  2. Aug 9, 2019 at 3:12 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    +25ish is around the offset the prevents running for a 12.5” tire. With an 11.5” tire, you should be fine.
  3. Aug 9, 2019 at 4:31 PM
    ctdomain
    Clint
    Dude you're still on! @the_midwesterner , this is literally the build you and I discussed months ago, I was finally able to start executing on things after moving cities and changing jobs lol, in Houston now.
  4. Aug 9, 2019 at 4:40 PM
    ctdomain
    Clint
    Also seems like finding +25mm offset wheels in 17in rim is kinda scarce
  5. Aug 10, 2019 at 5:55 AM
    Muddog
    Muddog New Member
    Bay Area California
    Kings front and Rear BMC Sliders 17s on toyo 35s
    I run Kings with +3 coach builders in the rear with a 17 inch wheel. Had to do a bmc to fit my toyos 12.5. With 11.5 you might be ok and not rub.
  6. Aug 10, 2019 at 9:45 AM
    ctdomain
    Clint
    @Muddog , do you know what offset you're running? wheels?
  7. Aug 11, 2019 at 7:47 PM
    Muddog
    Muddog New Member
    Bay Area California
