KING Shocks N2 Pressure & Fill
Discussion in 'Suspension' started by NW Elevated, Jan 24, 2019.
  1. Jan 24, 2019 at 3:35 PM
    NW Elevated
    NW Elevated [OP] New Member
    Seattle
    18' 5.7 Superwhite TRD Sport CM
    King 2.5's front & rear, TC shackles, Methods, Toyos
    So, I called King this morning and they told me they ship the front shocks charged at 125psi, and the rears at 90psi. From the couple posts I've seen, that sounds low/soft, but I really don't know any better. What pressures are you guys running?
    Am I also correct in assuming that I can just purchase the charging manifold from King and fill using any nitrogen tire shops airline (assuming the pressure is enough, and I'm at full droop)?
    Rica25 likes this.
  2. Feb 6, 2019 at 3:47 PM
    NW Elevated
    Seattle
    Bueller?
  3. Feb 6, 2019 at 3:47 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  4. Feb 6, 2019 at 3:58 PM
    Shipping pressure.
    Mine were shipped with zero pressure.
    125-150 psi is normal.
    dcsleeper408 likes this.
  5. Feb 6, 2019 at 4:59 PM
    n2deep
    n2deep Pavement Princess
    I run 180psi in my Kings
  6. Feb 6, 2019 at 6:45 PM
    N2deep brought up a good point that I should cover.
    2.0 shocks are 125-150 psi
    2.5 shocks are normally 180-200 psi.
    150 in a 2.5 can cause cavitation depending on use. I run slow stuff, so not as big of an issue.
    Now what @n2deep runs, this is critical. Good point.
  7. Feb 6, 2019 at 6:49 PM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I need to check mine just to see where they are at. I would like to do it myself as well. Any recommendations on what to use?
  8. Feb 6, 2019 at 6:50 PM
    Zero pressure loss fill kit.
  9. Feb 6, 2019 at 6:58 PM
    Jimes
    Jimes New Member
    Thanks. I’ll look it up. Love this forum for all the DIY info and help. It’s much appreciated. So much money saved on labor costs so I can put more mods onto truck. Good to know too while on a trail and something goes wrong.
  10. Feb 6, 2019 at 7:54 PM
    NW Elevated
    Seattle
    Thanks for the help! They’re 2.5’s, and 125 sounded low, just wasn’t sure how low. Are you guys running the same pressure in the front and rear, or less in the rear?
  11. Feb 6, 2019 at 7:59 PM
    Run the same on all corners.
    NW Elevated[OP] likes this.
  12. Feb 6, 2019 at 8:42 PM
    n2deep
    Sorry mine are 2.5's for now :D When King rebuilt them in the field he charged them at 200psi even though the endcap said 150psi. I backed it off when I blew an end cap off the Resi on a hard hit :eek::eek: But really think that was related to another issue.
