King/Fox/Icon rear shock guards?
Discussion in 'Suspension' started by pbcolt, Dec 4, 2018.
  1. Dec 4, 2018 at 2:23 PM
    pbcolt
    pbcolt [OP] New Member
    San Diego
    2022 SR5 TRD-OR CMSB Lunar Rock
    Searched and couldn't find anything.
    Is anyone running a shock guard/boot to prevent the lower mount from getting dinged up and the shafts from getting pitted due to rocks/dirt?
    Just installed Kings on the rear of my truck and would like to keep them as good as new for as long as possible.
  2. Dec 4, 2018 at 2:37 PM
    Vizsla
    Vizsla pretend2send
    I run boots on mine. Live in the desert so moisture isn’t a problem, but dust could build up and shorten seal life. No brainer for me, fine with rebuilding, rather not replace shafts also.
    georgiey22, joonbug, Jsena and 3 others like this.
  3. Dec 4, 2018 at 3:00 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Same, I run the shaft condoms as well
    TheBeast and pbcolt[OP] like this.
  4. Dec 5, 2018 at 7:49 AM
    pbcolt
    San Diego
    Right on, where'd you guys pick up your boots?
  5. Dec 5, 2018 at 7:59 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    you can get the daystars on Amazon
    pbcolt[QUOTED][OP] likes this.
  6. Dec 5, 2018 at 8:16 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    As smslavin mentioned, brand is daystar and you can smag them online or a local offroad shop should have them
    pbcolt[OP] likes this.
  7. Dec 5, 2018 at 7:20 PM
    mac10tuna
    mac10tuna New Member
    Marc
    19 cement limited CM
    Falcons new kit will come with them.
    JDL17CM4x4 likes this.
  8. Dec 6, 2018 at 6:51 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    not a fan of accordion boots... somehow I've always found debris in them when inspecting my shock shafts. I've seen people use a sheet like the one below. Cut it in 4" or 6" strips and mount it like the Falcon ones above. Just use a couple of zip ties. This way you can inspect and clean the shafts regularly. They are rubber, so they won't hurt anything and when they get beat up, a sheet is under $25. There's also different sizes if you need shorter or longer.
    https://www.homedepot.com/p/Rubber-...Sheets-and-Rolls-20-159-0125-12-012/304405312
    805ebr likes this.
  9. Dec 6, 2018 at 7:28 PM
    TheBeast The Beach
    King sells them in blue (boots).
  10. Dec 6, 2018 at 8:13 PM
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    Summit racing sells the king shock guard. Didn’t even know they made any.
    OPTPR251050 Is the part number.
    Samoan Thor likes this.
  11. Dec 15, 2018 at 6:53 PM
    805ebr
    805ebr New Member
    Kyle
    Presskit AZ
    2010 Tundra CrewMax
    Also run Daystar boots on the rear 2.5s. I use a hose clamp at the top instead of a ziptie.
    I like GravityGear's idea. Less stuff trapped sounds good.
  12. Nov 4, 2019 at 1:36 PM
    Keithbickford
    Keithbickford New Member
    Keith
    Seattle
    2020 Cavalry Blue Tundra
    King 2.5” suspension, Method Race 313 wheels, Nitto Ridge Grapplers 35x12.5x17, TRD exhaust, RCI Skid Plates, Alpine ILX-F309 stereo, Alu-Cab roof top tent on Yakima Overhaul HD, Line-X spray in bed liner, VLED LED reverse light bulbs and VLED LED license plate reverse light. VLED brake/tail light bulbs. VLED third brake light and cargo lights.
    King Shocks as well as other leading brands do not sell or recommend using boots. Debris and water WILL build up under the boots and damage the shaft. Instead, buy or make some shaft guards. You can use rubber sheet and a hose clamp. The rubber sheet literally just hangs vertically down from the shock body and in front of the shaft. This deflects rocks and sand kicked up from tires. Or you can get shaft guards from the manufacturer.
  13. Feb 1, 2022 at 7:52 AM
    Keithbickford
    Keith
    Seattle
    I’m late in my response, but the downside to boots is they’re meant to be zip tied top and bottom. This traps anything that gets in. Solution, cut the lower end off the boot and only zip tie the top to the shock body. 360° and water and dirt drain out. You can push it up out of the way to clean the shaft.
  14. Feb 1, 2022 at 8:15 AM
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Agri-Cover,RCI skid,ADARAC,Fox 2.0,TruDuals
    I put a Fox guard on the driver's side rear shock. A guard wouldn't fit on the passenger side facing forward because of how close the shock is to the axle. The axle shock mount actually shields the shaft pretty well other than the holes in it, so I just put some duct tape with flames to cover the holes...that easily added 10HP.
    Vang530 likes this.
  15. Feb 1, 2022 at 8:50 AM
    Keithbickford
    Keith
    Seattle
    Oh damn. You can’t add horsepower there. That causes axle twist. :). Actually, Ben at filthy Motorsports advised against the guards. He said a rock can get stuck in there. That makes sense. They look good. He suggested a piece of rubber in front of the shaft zip tied top and bottom.
  16. Feb 1, 2022 at 11:01 AM
    Torque
    Torque New Member
    Ft Collins, CO
    2016 DC TRD 4x4
    Crap, I thought I was brilliant putting it there to avoid the losses through the drivetrain. No wonder my springs are showing signs of wear.:rofl:
    Mine has been on for a couple years now, I haven't noticed anything building up in it, but I wouldn't expect gravel to get wedged in there. Gravel roads is the most extreme my truck sees. I'd probably install some boots if I was driving off road or in deep mud.
  17. Feb 13, 2022 at 8:01 AM
    Keithbickford
    Keith
    Seattle
    Why not cut off the bottom end of the accordion boot so that it’s open at the bottom. I’ve never seen it done, but it makes perfect sense to me.
