KING 3.0 coilovers
Discussion in 'Suspension' started by TheBeast, Oct 3, 2017.
  1. Oct 3, 2017 at 12:23 PM
    TheBeast [OP] The Beach
    was bound to happen ;)
    announced today. from their FB page.
    Toyota Tundra 3.0 Performance Series Kit, Front Coilover
    Features include:
    --Large 3.0 diameter shock bodies increase fluid capacity for smoother, cooler running shocks.
    --New design that features a lower coil adjustment for easier ride height adjustments and better fitment around various suspension components.
    --Large 3/4” Lower Bearings in a newly designed steel rod end for superior strength. --This is a 100% bolt on installation that requires no cutting or welding to be done to your vehicle.
    —Increase in wheel travel.
    --Extensive dynamometer lab testing and punishing real world testing to develop the optimal dampening curves and spring rates for your Toyota Tundra.
    --Manufactured with the same quality of materials and precise tolerances found on our high end race shocks.
    --Comes standard with King’s Wide Range Compression Adjuster that gives 20 precise clicks of compression dampening adjustment to further refine your ride quality.
    --Fully rebuildable, serviceable and tunable.
    Toyota Tundra 3.0 Performance Series Kit, Rear Bypass
    King’s new 3.0 Triple Bypass Rear Shock Kit includes our externally adjustable triple bypass shocks that allow you to adjust compression and rebound. Kings’ 3.0 diameter suspension system gives you better control and elevates your on and off-road performance to unmatched levels.
    Features include:
    -Fully adjustable 3 Tube Bypass Shock design allows you to adjust compression and rebound.
    -Bypass shocks have a built in bump zone for better bottoming control.
    -New Larger upper mount bushings for a tighter fit, better feel and increased noise isolation.
    -Large 7/8” Shafts and 3/4” bearings for superior strength.
    -Factory tuned for optimal ride quality.
    -Increase in wheel travel.
    3.0 Performance Series Kits come standard with all new 2.5 finned reservoirs – Features include:
    -External finned reservoirs dramatically increase fluid capacity, heat dissipation and provide sustained dampening performance even under the most punishing conditions.
    -Increase surface area helps to dramatically dissipate heat.
    -All new improved styling.
    -All new threaded end cap design with new Schrader valve protective cap.
    -Made from extruded 6061-T6 aluminum.
    -New improved styling reservoir clamps make it easy to mount. No more hose clamps!
  2. Oct 3, 2017 at 12:25 PM
    coilovers and triple bypass rear shocks....say whaaat ? wonder what the price will be.
  3. Oct 3, 2017 at 1:24 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    @jjstu123 these will work good on your truck!:stirthepot:
    Jsena and jjstu123 like this.
  4. Oct 3, 2017 at 1:26 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    so? when are you upgrading? :cool:
    Eclipsed & Floating and Filthy13 like this.
  5. Oct 3, 2017 at 1:39 PM
    Filthy13
    Filthy13 New Member
    NorCal
    2017 White 1794 TRD OR
    A few goodies
  6. Oct 3, 2017 at 1:44 PM
    :spy::spy: my current 2.5 only have 800 miles..let me recover..lol..I think 3.0 would be overkill for what I do....right now...:turtleride:
  7. Oct 3, 2017 at 1:51 PM
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    heh. mine have about 1100. if i do anything in the future, it'll be a double setup up front and a set of triple bypasses out back.
  8. Oct 3, 2017 at 1:53 PM
    as far as pricing it's probably gonna be up there though I would think.
  9. Oct 3, 2017 at 3:56 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I think they'd be a bit more expensive than ADS, probably in the $2300-2500 range.
    Jsena likes this.
  10. Oct 3, 2017 at 4:54 PM
    Tundras.com big boys want big toys :hattip:
  11. Oct 3, 2017 at 5:48 PM
    Tacotundra
    Vegas
    2022 Tundra
    Do it!!! Love my ADS 3.0's :thumbsup:
    TheBeast[QUOTED][OP] and Jsena like this.
  12. Oct 6, 2017 at 12:52 AM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    I had a chance to see these in person at the Off-road Expo in Pomona, Ca last weekend. Build quality is as expected, top notch. They’ll definitely be able to take a beating. I’m sure people’s wallets will take a beating as well.
    Watt maker and TheBeast[OP] like this.
  13. Oct 6, 2017 at 2:27 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Mmmm I like... o_O
    :thumbsup: Thanks for the heads up!
  14. Oct 6, 2017 at 9:26 AM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    You get them first and then I'll decide if I'm crazy enough to spend the cash.
  15. Oct 6, 2017 at 9:27 AM
    honestly they are probably overkill for 99% of us :)..I mean 2.5 are fine for driving over Prius ..
  16. Oct 6, 2017 at 9:28 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    That wouldn't be a bad price at all. The Icons run around 3k
  17. Oct 6, 2017 at 9:56 AM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    No kidding? Damn. I figured they'd be around the cost of ADS, last I heard they were around $2100 or so?
  18. Oct 8, 2017 at 5:37 AM
    Stevenboise
    Stevenboise New Member
    Old Man Emu suspension. Brute Force Fab front bumper, rear dual high clearance rear bumper, sliders and headache rack.
    I thought a triple bypass meant you were almost dead?
  19. Oct 20, 2017 at 2:45 PM
    M C M
    M C M New Member
    ADS Retail at 2776 for 3.0s with Clickers
  20. Oct 20, 2017 at 2:56 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Their rear bypasses won't be spec'd for deavers. Waste of money imo. Ads deaver spec'd 2.5s offer way more performance and are considerably cheaper. Still a much better option
  21. Oct 20, 2017 at 3:05 PM
    M C M
    M C M New Member
    I have contemplated doing the R&D to offer a 3.0 bolt in bypass like I did for the 2.5 bypasses, but honestly, have yet to have anyone really be disappointed with the 2.5" performance so it has yet to really be a priority. Plus, the 2.5" shocks already a somewhat tight fit with the lower shock mount. So for right now I am just working on the rear bumpstops as well as an updated version of my shock relocation for mounting a 12" shock under the bed with SUA leafs. I worked with ADS to make a Shortened 12" 3.0 Bypass to try out. Should be a fun set up for guys not wanting to cut into the bed.
  22. Oct 20, 2017 at 3:34 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I'd be ALL OVER a 3.0 deaver spec'd bolt in and I have friends who would too. We were excited to hear about the kings but we're out after learning they wouldn't work with deavers. Also interested in your new shock relocation but a little concerned with the shock angle of a relocation set up. My friend already had a very bad experience with the camburg kit. Definitely want to the most performance without cutting the bed and really not looking to do rear glass if I don't have to.
  23. Oct 20, 2017 at 4:10 PM
    M C M
    M C M New Member
    The first truck I did with the SUA kit has been running strong for 3 years now with no issues. The shock angle hit around 40* at full bump with 16" of travel, so it's not too excessive. My upper shock mounts are more robust as well. I'm currently doing the updated mounts on my personal truck and will be testing pretty soon.
    I'm not opposed to doing a bolt in 3.0 rear set up, especially if I see that the interest is there.
    I have 3 trucks including mine getting the new SUA shock set up here soon, so there should be some good testing soon. My truck already has I96, but we are waiting on some sets of the I96 HD amd XHD to come in for the other trucks
  24. Oct 20, 2017 at 5:16 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    I honestly doubt they will ever release it. They did the same thing last year right before SEMA with the 3.0 Tacoma coilovers and 3.0 Tacoma rear 3T bypasses. They never ended up producing them.
    Icon's 3.0's retail at $2800. So I would ballpark in that region. King and Icon are generally pretty close and ADS is in the same ballpark as MCM mentioned above. If King does end up doing these, hopefully they do an internal bumpstop in it because the ones in the Icon shocks are game changers.
    Watt maker and M C M like this.
  25. Oct 21, 2017 at 11:25 AM
    n2deep
    n2deep Pavement Princess
    There isn't enough space for a 3.0 and SOA. The only real way to get the 3.0 is SUA. The Kings are about $2500 but they will have clearance issues with K37's so might be why they aren't spec'd for Deavers.
    040Tundra likes this.
  26. Oct 22, 2017 at 1:20 AM
    SpeshulED
    Do you know if the Icon rear bumps will fit with rear King’s with External Resi?
  27. Feb 23, 2018 at 4:34 PM
    Theonlyway
    Theonlyway New Member
    User
    Still not released?
    JH6124 likes this.
  28. Feb 23, 2018 at 6:15 PM
    SpeshulED
    Although I love and run their products it’s hard to get a hold of anyone especially when via email. I wouldn’t hold your breath.
    JH6124 and Theonlyway[QUOTED] like this.
  29. Feb 24, 2018 at 2:39 AM
    JH6124
    JH6124 New Member
    California
    2011 Toyota Tundra Rock Warrior
    King 3.0 coilovers in front King 3.0 3 tube bypasses in rear Camburg UCAs 35” General x3 Grabbers Painted head light Mod Method 17” double standards Smoked tail lights and 3rd brake light. KC Hilite A pillar cube LED lights. Pedal commander
    I ordered them about a week ago. 3.0s for front and 3.0 bypasses for rear. Can’t wait to get them and have them installed.
  30. Feb 24, 2018 at 6:27 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Any chance you could release pricing via PM?
    GodlessPro likes this.
