KING’s vs 6112’s
Discussion in 'Suspension' started by textundra12, Dec 1, 2022.
  1. Dec 1, 2022 at 8:39 AM
    textundra12
    textundra12 [OP] New Member
    Looking at doing a Small lift for my 2020 trd sport. Originally planned on doing 6112 and 5160 with a 1.75 leaf spring lift in the back to maintain rake.
    However now I’m considering something a little more premium with KING 2.5 remote reservoirs in the front and something matching in the rear.
    My question is - for those who have experience with both of these sets. Which would you recommend? How would you describe the ride qualities vs stock for each?
    It’s been years since I’ve lifted a vehicle
    5N0W808 likes this.
  2. Dec 1, 2022 at 8:45 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    You wont regret the kings, the billies are good. but adjustability is a big factor to consider. Fine tuning is really nice.
  3. Dec 1, 2022 at 9:06 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    This isn't really a comparison. Its apples to rocks.
    Kings:
    Progressive piston, more cushier ride that firms up as shaft speed is increased. Better components, better valving, and premium product.
    Billies:
    Digressive piston, so firmer ride that then firms up further as shaft speed is increased. Mass produced components. Unknown valving to me, but its a digressive piston and I am not a fan. Definitely less of a premium product and in my biased opinion, the wiper seal tech they use on bilsteins sucks. All wiper seals will leak eventuatlly, but i've had 5100, 6112, 7100s and their coilovers which all leaked from the wiper seal area.
    As a side note, if you look up radflo and why that company was started in the first place, the owners say that they started making shocks because they couldn't keep bilsteins from leaking. Food for thought.
    If you want to nerd out: Accutune has a pretty good series on shock info.
    Piston description reference:
    chugs, 5N0W808, ColoradoTJ and 4 others like this.
  4. Dec 1, 2022 at 9:09 AM
    mass-hole
    mass-hole New Member
    Digressive might not be as good for pure offroading, but I would argue its probably better for daily use. What if the guy tows? Does he want a shock thats soft initially for when hes hitting undulation on the freeway with 800 lbs of tongue weight on the hitch?
    BTBAKER likes this.
  5. Dec 1, 2022 at 9:10 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Are you really gonna use the Kings? If not, save your money for something you'll actually use.
    Hbjeff likes this.
  6. Dec 1, 2022 at 9:12 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    The 6112s are throwaway shocks I believe, I don't think you can rebuild them. So in the long run the Kings are probably cheaper too.
    831Tun likes this.
  7. Dec 1, 2022 at 9:14 AM
    the_midwesterner
    Luis
    None, yet....
    Sure... i guess. Shocks aren't supposed to be load carrying objects though. That's a spring issue. Also, the beauty of the kings and their compression adjusters is that you can change them on the fly. The inverse can be asked about the digressive piston without a flutter stack on washboard roads. 6112s straight suck in the situation. Also, soft is relative. Are they softer? yes. Are they soft? nope. Your situation would quickly engage the valve stack depending on shaft speed. However, if he gets the adjusters, he can increase the compression resistance to his liking and address the hypothetical that you mentioned.
    ColoradoTJ and 5.7TRDProm like this.
  8. Dec 1, 2022 at 9:14 AM
    mass-hole
    How long of a run though? I have had Bilstein 5100's on my F150 for nearly 90k miles and they are still solid. How many times would the Kings have been rebuilt at that point? Probably enough times to buy a set of 6112's
    831Tun likes this.
  9. Dec 1, 2022 at 9:18 AM
    mass-hole
    100%. Perfect example is my F150. I put air bags in the rear to help support the load of my fiberglass topper and hundreds of lbs of camping gear. Sure it stiffened it up and corrected the ride height but still wallowed around because it was underdamped.
    Yes, he could get the adjusters to the tune of $1500 for just the rears and $2300 for the fronts, when a set of 6112's and 5160's are no more than $1100. You are literally talking >3x the price for a guy who is apparently just wanting to lift a truck.
  10. Dec 1, 2022 at 9:21 AM
    Pmac
    Pmac New Member
    South of Portland, OR
    2019 CrewMax TRD Off-road
    I prefer the digressive for daily use. Truck does not float/dive in corners etc. as much, I do tow, off road some and like my truck to feel like a truck with a firm ride. Currently have 5100’s up front set for the lowest lift setting, and happy with them. Factory TRD Off-road in back. Works for me and low $ solution.
  11. Dec 1, 2022 at 9:24 AM
    the_midwesterner
    Luis
    None, yet....
    I didn't see anything in his post that said price was an issue? He asked for feedback and I gave him technical feedback based on my experiences and shock rebuilds I do on the side.
    ColoradoTJ, TundyMcTunra and Y0TA PR0 like this.
  12. Dec 1, 2022 at 9:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    ADS also makes a great shock. I would throw that in the mix over the bilstein.
  13. Dec 1, 2022 at 9:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I don't think the King's would "need" to be rebuilt any more than your billies. The thing is, you can rebuild them and change valving if you so desire. The King parts are readily available and rebuilding is kinda fun or at least educational. The potential setback to rebuilding your own shocks is the requisite nitrogen recharge. I've invested about $300 in nitrogen fill equipment. But, nitrogen pressure is a large factor in how the shock performs ie. stiffer/softer. For me, with 6 shocks and 2 bump stops it's well worth the investment especially since I opt to rebuild my shocks very frequently ~20k miles.
    That said, I'm not advocating King, Fox, ADS as the appropriate choice for everyone. For a lot of drivers the premium shocks make no sense, they'll never realize the benefits. For some the bling factor will make 'em happy. Others require premium shocks primarily for off road performance.
    ColoradoTJ, des2mtn, joonbug and 3 others like this.
  14. Dec 1, 2022 at 11:04 AM
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    I hear that a lot and I suppose the same could be said for any upgrade we install on a vehicle. Are those off-road tires really necessary? Are those nice wheels necessary? Do you really need that light bar? etc...
    The way I see it, suspension is like the seats in your truck or the bed you sleep on at night. You will actually be using it every day. Quality off-road suspension will absolutely ride nicer than cheaper shocks. They are not designed for off-road only. Same with the bed you sleep on. You get what you pay for. Personally I really enjoy driving my truck every day with the upgraded tuned Fox suspension. Being comfortable on long road trips has been awesome. IMO, The value is there since I feel it and use it daily. If you plan on keeping your nice new truck for many years and drive it daily, I would definitely look into a nicer set of shocks and invest for the long term ride quality benefits. Just my .02
  15. Dec 1, 2022 at 11:23 AM
    C.I.
    C.I. Surf, off road, sleep, repeat
    Cesar Pedrin
    Cabo, Mx
    2016 5.7 4x4 Bronze Crewmax
    Mods: Ongoing... probably never ending
    Thats not how shocks work. Rebuildable shocks have a minimum recommended service interval of 50K KM, however this interval can be severely reduced to just few thousand KM depending on use. Mall crawlers can easily reach the 50K minimum while heavy offroading cuts it down to 5-10K km and as little as 2-3K (prerunning).
    No diffrent than an engine or transmission needing shorter maintance intervals from lots of towing, etc.
  16. Dec 1, 2022 at 11:37 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I agree. I ride on Foxes lol. However, Bilsteins aren't trash. I can remember when my Dad bought shocks at the local parts counter and he told me we couldn't afford the best but could definitely afford better. He bought Monroe or Gabriel lol. Hell, none of us would put that on our trucks. Bilstein was a brand that I looked up to growing up.
  17. Dec 1, 2022 at 4:12 PM
    textundra12
    I dont tow anything regularly. I am building a capable truck that’s still daily drivable. I off road when i go hunting but I’m not doing any extreme over landing (hence why i only want a 2” lift)
  18. Dec 1, 2022 at 4:16 PM
    textundra12
    Every week? No. 6 times a year? Yes.
  19. Dec 1, 2022 at 4:19 PM
    textundra12
    Every hunting trip involves about a 5 mile drive down a washboard dirt road. Something that absorbs that would be worth the money
  20. Dec 1, 2022 at 4:21 PM
    textundra12
    I wear a dive watch daily and I’ve never been for scuba diving once lol
    TundyMcTunra likes this.
  21. Dec 1, 2022 at 9:13 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I daily drive my ADS equipped 2018 and would not ever want less after having these. An investment (can you call it that?) for sure, but it’s no joke how well it performs. I do get it off road occasionally, but let’s be honest. Less than a day per month on average. Still, it’s nothing but grins when I bomb through bumps, dips, drops, hollows, wallows, humps, and thumps. Hauling ass up washboard logging roads at 50+ mph without spilling my coffee? Not sure I could do that with 5100’s…
    reywcms likes this.
  22. Dec 2, 2022 at 3:28 AM
    matt kruckenberg
    matt kruckenberg New Member
    slc ut
    2015 Trd Pro Inferno
    dont rule out ICON ive had no issues with mine
    3.0 up front 2.5 rear about 3 1/2 years
    SAGE63 likes this.
  23. Dec 13, 2022 at 7:03 AM
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    Agreed, I had ADS on my 2011, loved them. Have Kings on my Sequoia. Definitely worth the money if you can afford them. Wouldn't hesitate to go with AccuTune's Fox's though either.
    AccuTune Offroad likes this.
  24. Dec 13, 2022 at 7:11 AM
    king.cong.1119
    king.cong.1119 New Member
    What do you need for ur shocks to do? If just looks and not a lot of fast off-roading, 6112/5160 is perfectly fine. Heck it’s already much better than stock and lots of the basic suspension kits for tundra. I have been using them for two years and they hold up fine in my daily commuting and off-roading once a month. But. I don’t do any fast off-roading, if that’s ur thing then kings or fox, if not, then bolstering is fine.
    ShinyConcretE likes this.
  25. Dec 16, 2022 at 10:34 PM
    ThiRdChoice
    ThiRdChoice New Member
    Tommy
    I just recently bought a 2020 platinum and love the car. I want to add a lift for the look and to add some all terrain tires (total noob with lifts and this is my first truck haha). I found the 6112/5160, they aren't crazy expensive and fit within my budget. Do you have any other recommendations for < $2000? I don't do any off roading (if anything maybe 1x a year for a camping trip) and I don't tow anything yet (possibly a boat in the future).
    Also, how large of tires can you fit? I was hoping to fit 35s.
  26. Dec 16, 2022 at 11:46 PM
    SAGE63
    San Diego County
    I have my take-offs listed for sale on here. 6112/5160, +3 CB shackles, 3 CB shims and Builtright uniball UCAs... went for the big boys 3.0 ICON CDVC Coilovers, 2.5 OMEGA R/R bypass, ICON billet UCAs and ICON RXT leafs...I like going 60+ MPH across the desert..... I really liked the Bilsteins setup until the extra 250lbs from the C4 bumper and winch setup dropped my front over an inch. I am also pretty damn Heavy... 7200lbs
  27. Dec 16, 2022 at 11:59 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    You only live once, go with kings! :D:thumbsup:
  28. Dec 17, 2022 at 9:24 AM
    king.cong.1119
    Since I only have used stock and 6112/5160, I can’t really recommend anything else I haven’t used, so far I love my 6112/5160, they provide close to stock look and much better on road/Offroad than stock, I have used mine extensively Offroad and so far it meets my need. If I ever wanted to do fast off-roading, maybe kings but I don’t see that in my near future. Also, I have fit 35s no problem, as long as you have +25mm offset wheels (perfect for fitting 35s on our gen tundra)
    ThiRdChoice[QUOTED] and SAGE63 like this.
  29. Dec 19, 2022 at 9:59 AM
    ThiRdChoice
    Tommy
    I won't be using it for off road so it'll just be for on road riding mainly. What height setting do you have yours on to fit 35s? I'm guessing max height at 2.5"? If so, is the ride any different than stock (stiffer?). Did it require any cutting/trimming to fit the 35s? I may make a post just so I can get some more suggestions as I plan to get this done this upcoming summer.
  30. Dec 19, 2022 at 10:00 AM
    king.cong.1119
    I have mine set on 1.9inch lift, believe it’s the second from bottom notch. Only trimming needed are removing the mud flaps and heat gun the front plastic area.
