kickback
Discussion in '2nd Gen Tundras (2007-2013)' started by ausei, May 29, 2015.
  1. May 29, 2015 at 6:11 PM
    ausei
    ausei [OP] New Member
    Ause
    Baton Rouge, LA
    2011 Spruce Tundra TRD SR5 2WD
    3" Leveling Kit 3.5" Spindle Lift 4" Rear Blocks AirAid Intake 20" XD Monsters w/ Nitto Grapplers 1" wheel spacers for rear Magnaflow Exhaust Pro Comp Shocks for rear
    ever since i lifted my truck i am getting some sort of kickback feeling when im at a stop. idk if its the transmission downshifting or what it is. anyone had this issue with lifts?
  2. May 29, 2015 at 6:37 PM
    Mike Tread lightly.
    south carolina
    Two things i can think of other cant be you, your 2wd
    One like you said transmission downshifting.
    Two You center carrier bearing and or the ujoints are at to high of a angle and binding up some do to lift. You can drop the center bearing try some washers and longer bolts see if the angle helps. Only other thing you can do is shim the axle up some so the ujoints are not that high of angle...
    One more thing when was the ujoints greased last?
  3. May 29, 2015 at 7:53 PM
    Does it do it when coming to a stop? anyway you can record this? I just want to eliminate that's it's the trans downshifting based on ur driving patterns.
  4. May 30, 2015 at 8:46 AM
    ausei
    Ause
    Baton Rouge, LA
    after driving. not all the time. ill come to a stop. and ill feel a jerk in the drivetrain.
  5. May 30, 2015 at 8:47 AM
    ausei
    Ause
    Baton Rouge, LA
    i havent greased anything...only since the squeking noise from the leaf springs til i get time to stick bicycle tubes between them
  6. May 30, 2015 at 8:50 AM
    ausei
    Ause
    Baton Rouge, LA
    haha on the 2wd. ive seen people doing that...i have those 4" blocks and they were sloped at angle to help with that.
  7. May 30, 2015 at 8:51 AM
    ausei
    Ause
    Baton Rouge, LA
    ive also noticed that when im at a stop and switch over to the sport shift. its already in 4th gear. is that how everyones is?
  8. May 30, 2015 at 9:13 AM
    Mike Tread lightly.
    south carolina
    What about the center bearing in the drive shaft? If it hasnt been lower you might have problems there.
    Ujoints need to be greased every 5000 miles. If they run low they can cause all kinds of weird noises.
    If you had 4wd diff drop plus angle turn to keep angles on the ujoints minimum.
  9. May 30, 2015 at 11:08 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's the default behavior. I've never read of it being something that can be changed.
  10. May 30, 2015 at 2:05 PM
    Yep.
  11. May 30, 2015 at 4:01 PM
    I think 5th and 6th are the overdrive gears per manual. Default to 4th because of safe shift point?
  12. May 30, 2015 at 4:02 PM
    Mike Tread lightly.
    south carolina
    I thought is was 3rd gear on 2nd gens.
  13. May 30, 2015 at 4:04 PM
    Mine always goes to 4th. Maybe it's 3rd with 4.6L tranny.
  14. May 30, 2015 at 4:13 PM
    Mike Tread lightly.
    south carolina
    Probably. I will check the data on it.
  15. May 30, 2015 at 4:34 PM
    Mike Tread lightly.
    south carolina
    What I seening the tranny controls speed when limp mode. Engine size doesnt matter. By the looks of it. Do to fly by wire system.
  16. May 30, 2015 at 4:54 PM
    I was thinking the 4.6L had a 5 speed , but wrong i'm wrong on that.
  17. May 30, 2015 at 4:59 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    You might be thinking of the 4.7L.
  18. May 30, 2015 at 4:59 PM
    Mike Tread lightly.
    south carolina
    I was looking at limp mode and max speed. Ugh. Looks like you can get the 4.6 in a six speed gearbox or 5 ? Im guessing what ever the dealer orders it I guess.
  19. May 30, 2015 at 5:05 PM
    I'm not sure what i'm thinking now. Heh heh
  20. May 30, 2015 at 5:11 PM
    ausei
    Ause
    Baton Rouge, LA
    I have a 6 speed.
