Keyless Entry & LEDs
Discussion in '2.5 Gen Tundras (2014-2021)' started by ATCRich, Apr 24, 2019.
  1. Apr 24, 2019 at 6:43 AM
    ATCRich
    ATCRich [OP] New Member
    2019 Super White DC TRD Sport 4x4
    I've been experiencing issues with my remote keyless entry for the past few weeks on my brand new Tundra. It would work intermittently, or sometimes not at all. The local dealer replaced the module in the headliner suspecting that it was the issue. Well the problem continued. So, I had it back to the dealer this morning, and through information from the Toyota Tech line, we learned that the installation of LED bulbs interferes with the remote keyless entry in the new Tundras. So, the nice kit I got from Precision LED will likely have to be removed. Not happy. Anyone else experiencing similar issues?
  2. Apr 24, 2019 at 6:54 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    It has been mentioned on here a few times.
    Same but different: A while back my garage door remotes got real iffy, not working most of the time or range was significantly reduced. Research and tech support pointed to new LED lighting in the area,
    my house and neighbors. I had to upgrade my keypad and remotes.
    The LEDs somehow interfer with certain frequencies.
    ATCRich[OP] likes this.
  3. Apr 25, 2019 at 8:46 AM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
  4. Apr 25, 2019 at 8:48 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    If you're looking for another set, I've been using the ones from Headlight Revolution w/no issues.
  5. Apr 25, 2019 at 9:10 AM
    ATCRich
    THat was suggested by the Toyota Tech Line, so there may be something to it. Thanks and I'll give it a try!
  6. Apr 25, 2019 at 9:10 AM
    ATCRich
    Thanks! Will look into it!
  7. Apr 25, 2019 at 9:46 AM
    Professional Hand Model
    Hand Protectors
    Years ago I had the same issue with my 2002 Tundra AFTER replacing the cargo 3rd brake light bulb AND the 2 adjacent bulbs to LED at the same time.
    What happened after was my fob stopped working at distance and only worked when about a foot away from the truck.
    Lived with it until recently and switched to the ZEVO Sylvanias for the 2 cargo bulbs and my fob works at distance again. The brake light still has the old LED bulb. Seems as if its just the cargos (with cheap LED bulbs) that mess things up.
  8. Apr 25, 2019 at 9:51 AM
    ATCRich
    Great! Thanks for the info!
  9. Apr 25, 2019 at 1:18 PM
    ncorry
    ncorry New Member
    Nic
    Little Rock, AR
    2019 CM SR5 TSS
    Mine was the opposite. I went with cheap ones from Amazon and have no problem. The thread I linked to above indicates that it is the VLEDs, as well as OP's $40 Precision LED cargo bulbs that are the culprits.
  10. Apr 25, 2019 at 1:48 PM
    Hand Protectors
    Buy ZEVO Sylvanias then. That fixed mine.
    Tracy Perry likes this.
