Keyhead Transmitter Sometimes Won't Lock Doors
Discussion in '2.5 Gen Tundras (2014-2021)' started by bfunke, Feb 7, 2022.
  1. Feb 7, 2022 at 3:31 PM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    South Carolina
    My 2018 TRD Off-Road Crewmax recently started acting weird. Intermittently when I drive to work in the morning and park my truck, I can't lock the doors with the integrated keyhead buttons even though I'm 5-10 feet away from the truck. This lasts about one minute or so until the lights shut off and it then seems to work. I doubt it's the small battery in the key as my office is at least 100 yards from where I park and I can see the lights flash when I press the buttons even that far away (it's uphill with direct line of sight). This past weekend I replaced the truck battery due to the OEM failing leaving me stuck. The only other thing I've done to my truck was update the ENTUNE Plus firmware with 13TDDANA-DA10_0123.kwi file I found elsewhere on this site 3 weeks ago. My question is whether the Keyhead receiver is affected by or controlled by the ENTUNE software. My entertainment system works just fine. Thoughts?
  2. Feb 7, 2022 at 4:12 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Did you install led lights anywhere on the truck?
    AggiePhil likes this.
  3. Feb 7, 2022 at 4:17 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
  4. Feb 7, 2022 at 4:27 PM
    bfunke
    South Carolina
    No. It has factory LED headlights but everything else is stock
  5. Feb 7, 2022 at 4:32 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Not even the exterior cargo light? Only time I’ve heard of this is when folks change out bulbs to LED’s personally. I wouldn’t think Entune would have anything to do with locking and unlocking the vehicle aside from the settings you can change, like unlock driver door only or all doors, or the feedback tone. There’s definitely something fishy and familiar about it working after the lights timeout though.
  6. Feb 7, 2022 at 6:28 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    I have had this happen to my truck. Happens alot when my led construction strobe light is on. If its off never a problem.
